My 68 has AN positraction - the question is was that limited slip and with 1 rear tire jacked up off the ground should I be able to ture the tire a 1/2 turn with the other tire still sitting on the ground?
If it is a posi and it is still in good shape no you cannot turn it, maybe with a lot of force you can. They can be worn out and the clutch packs shot allowing this so it may be a posi just a worn out posi.
It is also possible that the box in your car does not have the Positraction option (G81). Positraction, while very popular and almost every Corvette was ordered with it, was still an option. The 'standard' rear axle was not a Positraction unit until 1976 or 1977.
Yes the car has positraction the stamp on the rear end is AN= 3.55 positraction.
The rear tire really only turned between a 1/8 and 1/4 turn then it seamed to lock in place and will not turn now. I had one of the half shafts replaced a few months ago and maybe the shafts were not lined up properly like they are suppose to be at 90* off from
each other.
I would guess with 100k miles that the differential is becomming a bit tempermental.
each other.
Drive around the block once or twice and the shafts might line up properly.
each other.
A little slippage is normal. Don't look to spend $500 unnecessarily. I would first change the differential oil, making sure to add a bottle of GM Posi additive. Drive it gently for a few miles, turning right and left a few times.
The, on a nice clean road surface, do a little burnout. Not the John Force type, just a little one to verify you lay down two good stripes. I expect you will see a good pair.
Also, mileage has nothing to do if the positraction unit is worn out. Poor maintenance and abuse do.
Change the lube.
Reason: oops. Spelling error
I'll disagree with you on this slightly. Mileage has everything to do with the posi being worn. The only time the clutches are slipping is when going around a turn. A burnout will not have the clutches moving at all providing you are in a straight line. Now doing donuts in a parking lot and burning out around corners yes that will wear them out. Changing fluid on a smoked set of clutches will not briing them back. The only way to really test this is with a torque wrench and test the breakaway torque required to turn one wheel while the other remains stationary. You are right though most of the posis even worn will do fine on a mildly driven car. They will provide 2 nice streaks on the pavement, unless the posi is totally shot.
You probably have posi, but with that kind of age/milage, good idea to pull the diff cover, drain and inspect things. I've seen spider gears weld themselves to pinion shafts, shear the bolt and start wearing against the housing. Posi clutch pack wear is common, and probably worth replacing. Careful with friction modifier additives, while usually quiet things around turns, can really cut down on posi clutch lock up action when you're wanting it.
AGREED!!! Mild street use the torgue to turn an outside wheel is from 100 to 140 foot pounds. Less than that the posi needs work!
