Gear Drive Question
Old Jun 18, 2011 | 11:49 AM
Jackk's Avatar
Jackk
Default Gear Drive Question
On the crank gear, which side goes against the crank? the side with the ridge or the undercut? With number one at tdc where should number one intake be?
Old Jun 18, 2011 | 12:25 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The bevel goes back against the crank to allow for the fillet radius where the snout of crank is machined. Should be a timing dot on the other side to line up with the dot on the cam gear.
Don't worry about valve position at this point. Line up the dots with crank gear at 12 oclock and cam gear at 6 oclock. That will have #6 at TDC compression and #1 with valve open on overlap. When you turn the crank one turn and the crank gear is at 12 oclock and the cam gear is at 12 oclock you will be on #1 TDC compression stroke.
JIM
Old Jun 18, 2011 | 12:33 PM
78 silver 78's Avatar
78 silver 78
I don't understand the question. Your crank and cam gear should have a dot on one side,like the timming chain gears. Gear sets come with " buttons " to set cam advance or retard, shims and a large cam button to keep gear from hitting timming cover. Some gear sets won't work with stock timming covers. Also some require some grinding of the block. Not sure what you mean in second question. At TDC, both intake and exhaust valves will be closed.
Good luck.
Old Jun 18, 2011 | 01:06 PM
Jackk's Avatar
Jackk
Thanks, this gear set is a copy of the Miloden style, for a friends car not mine. Does not have dots. But you answered my first quetion.
To Gear Drive Question
