Wheel Size?
Just bought this '69, and I want to put some wheels on it, probably Torq Thrust D's. I know the original wheels are 15x8, but I'm wondering if 15x10 will fit on the back without looking stupid? Any info on this would be greatly appreciated.
or your choices are SO limited you buying wheels, maybe as well update to something useful....
now as to style/price, to each his own....I bought a set of used '89 vette wheels....had a set of VBP 2.5" thick wheel adaptors on there....they are NOT spacers, but machined from solid good aluminum billet...and so are strong, with removing TEN lug nutz to get to the rotors...different animal than that junk your see from Mr, Gasket..cast potmetal crap....
so there are several things to watch for, and clearing the calipers in number ONE, then that ebrake cable mount, you will find wider wheels will most likely limit the steering radius in front, assuming you have the same size rims all around....like I do...
https://www.rsracing.com/tech-wheel.html#torque
Ron
I had to use a 1/2" spacer behind the rear and frt wheels to clear the calipers.
I like the look but not wild about the spacers. I plan on putting longer studs in. I think they still have enough threads without adding new studs but not going to take that chance.
Rodney
