1980 Qjet question
Old Jun 24, 2011 | 07:54 PM
kf4cln's Avatar
kf4cln
Default 1980 Qjet question
Hello all,
I have a 1980 with the original Qjet. The problem I have is, if I stomp on the gas the car accelerates fine at first then seems to have a stall and wont pull at all. If I gently accerate it will will pull hard untill you get way past 80.I guess I need to know a few things to check, just a few hints would be appreciated.
Rob
Old Jun 24, 2011 | 10:10 PM
'75's Avatar
'75
A few ideas to check.
Carb float level too low
Weak fuel pump/low fuel pressure
plugged fuel filter/plugged sock in tank
kinked "S" hose for the fuel pump inlet at the frame
Old Jun 25, 2011 | 03:44 AM
Kevin79's Avatar
Kevin79
I think 75 is right, look for a fuel issue. when the 4 bbl's kick in on wot it sounds like your running out of gas. i would also look for dirt or cloged secondarys inside the carb. depending on how long it has been sence the last rebuild it might be time for a carb soak and cleaning.
Old Jun 25, 2011 | 10:32 AM
7T1vette's Avatar
7T1vette
In order of probability: clogged fuel filter in carb inlet housing; kinked rubber fuel line at fuel pump area (likely if you have done work in that area recently...less likely if you haven't); float level set too low in carb (or some other mechanical problem in the carb that causes fuel flow to shut off prematurely); plugged up sock filter in fuel tank; nearly failed fuel pump not producing enough flow for WOT function.
Old Jun 26, 2011 | 05:11 PM
Rich's'78's Avatar
Rich's'78
Seems to me you have a fuel flow rate problem - okay at low demand but NFG for high demand. Previous suggestions are good, but also check tank is venting adequately - causes same symptoms.
Old Jun 26, 2011 | 05:32 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Add to the above...
Check the tension on the secondary air valve - if it's too loose, you will have a huge bog!
Old Jun 27, 2011 | 08:16 AM
Rich's'78's Avatar
Rich's'78
On furthur thought, could be HEI related. Hard accel generates the most demand on ignition so could be coil or dwell control module.
Another fuel thing, is these carbs have secondary accelerating well tubes and main well bleed tubes for emusifying secondary fuel - both are known to fall out (pressed fit)! Seen that on a few carbs.
Old Jun 29, 2011 | 05:43 AM
kf4cln's Avatar
kf4cln
Thanks all for the tips. This weekend will be a learning one.
Old Jul 27, 2011 | 09:32 PM
indydoug's Avatar
indydoug
I have the same problem with mine - I'll be troubleshooting as well (as soon as I install the new radiator!) Please post what you find, and I'll do the same.
To 1980 Qjet question
