New headlight relays, now problem???
Old Jun 28, 2011 | 12:57 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default New headlight relays, now problem???
Hi all
I just replaced my relays on my 74. Now when I turn her on the lights pop up. I didn't have that problem before. The vac lines are hooked up properly. the actuators have been rebuilt and the headlight switch is 1 year old. Any help would be greatly appreciated.
Old Jun 28, 2011 | 01:00 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
have you checked your bypass sw?
Old Jun 28, 2011 | 01:38 PM
...Roger...'s Avatar
...Roger...
Read this thread and your problems will be solved.
http://forums.corvetteforum.com/c3-t...tem-works.html
Old Jun 28, 2011 | 04:11 PM
jbaron's Avatar
jbaron
For some reason that page will not come up.
Old Jun 28, 2011 | 04:31 PM
78IndyPace's Avatar
78IndyPace
Here's the complete link:
How Your Headlight Vacuum System Works
If both headlights pop up when you start your motor, I think it's most likely the "top hats" of your new relays are not getting vacuum.
First check that your bypass valve under the steering column is UP as mentioned by dar322. If it is up and you still have the problem, then triple check all your hose connections between your "top hats" or your relays and your check valve.
Old Jun 28, 2011 | 07:20 PM
jbaron's Avatar
jbaron
Thanks for the advise and article! I'll check it when i can.
To New headlight relays, now problem???
