Ignition cylinder removal ?
Old Jun 29, 2011 | 11:48 AM
LawN4cr10's Avatar
LawN4cr10
Default Ignition cylinder removal ?
Does anyone know how to remove the ignition cylinder from the steering column without the original ignition key? I don't want to damage the steering column or any of the other components.
Old Jun 29, 2011 | 11:55 AM
7T1vette's Avatar
7T1vette
Doing that on your car is called "repair"...but doing it on someone else's car is called "theft". Maybe that's a trick best left to the locksmiths???
Old Jun 29, 2011 | 11:56 AM
Mashman's Avatar
Mashman
Yo need to look at Jim Shea's papers. There is a procedure to remove the cylinder without the key.
http://jimshea.corvettefaq.com/?cat=5
Jim is also a member here, so after reading the procedure, I'm willing to bet that if you have problems, Jim will be able to help you.
Pretty much anything Jim says should be taken as gospel, the same as Lars.
Old Jun 29, 2011 | 11:59 AM
bluthundr's Avatar
bluthundr
There is some good info here - http://jimshea.corvettefaq.com/?cat=5
^ Beat me to it!
Old Jun 29, 2011 | 01:18 PM
08vycpe's Avatar
08vycpe
I rebuilt my column using Jim's papers. Excellent resource. I cut down the width of a band saw blade to use in the slot that releases the cylinder when you get to that point in Jim's papers.
Old Jun 29, 2011 | 02:26 PM
Jim Shea's Avatar
Jim Shea
What year Corvette? What type steering column; standard (non-adjustable) or T&T?
It is not that bad a job. You will need a steering wheel puller. If you have a T&T it is best to borrow, purchase, or rent a special lock plate compressor tool in order to more easily remove the locking plate.
Jim
Old Jun 29, 2011 | 10:39 PM
LawN4cr10's Avatar
LawN4cr10
It is a 72 with a standard steering column. I bought the car as a project and the previous owner did not have the ignition key. So I am trying to remove the old cylinder so that I can install a new one.
Old Jun 30, 2011 | 08:03 AM
Jim Shea's Avatar
Jim Shea
Here are complete instructions and pics on replacing the ignition lock cylinder in a 1969 through 1976 Corvette standard (non-adjustable) steering column:
http://jimshea.corvettefaq.com/wp-co...dr1-22jn07.pdf
http://jimshea.corvettefaq.com/wp-co...trpage1pdf.pdf
Jim
Old Jul 5, 2011 | 10:44 AM
LawN4cr10's Avatar
LawN4cr10
Thanks for all your help Jim! That worked!
To Ignition cylinder removal ?
