Tremec install. ALMOST in. Thoughts?
Old Jun 30, 2011 | 09:05 AM
TPIShark's Avatar
TPIShark
Default Tremec install. ALMOST in. Thoughts?
So I loaded a Tremec 5-speed into my '75 4-speed car the other day. Like many have said on here, if you don't want to cut the crossmember, you can still get it in, but it's difficult. Three attempts, and some bruises later it's in. Only way that worked for me is shoving the trans as far back as you can, while still tilting it down to slip the bellhousing in loose. then raising them up together. (Clutch already installed). It's a tight fit, but was done with no bloodshed, or broken fiberglass.
Now for my problem - It's a 1/2 inch from the face of the bellhousing, and will go in no further. The alignment tool glided in and out perfectly. I know from having the bell housing and trans together on the bench, it's a very exact fit, which is to be expected. I'm thinking pehaps the disc moved. Now that the bellhousing is bolted to the block. I was thinking about installing the linkage, and having my partner activate the clutch, while I try to push it in the rest of the way. I seem to recall this method working with a T-5 years ago...
Old Jun 30, 2011 | 09:29 AM
1Fordman's Avatar
1Fordman
Don't know if this would apply in your situation, installed a Tremec in a 67 Fairlane with a 427 and had the same thing happen. Turned out the part of the input shaft that rides in the pilot bushing was 9/16" to long causing it to bottom out against the crankshaft. Had to have the end of the input shaft shortened to get the case to bolt to the bellhousing.
Turned out it was an oops from the kit supplier, they forgot to have the shaft machined shorter before shipping it.
Old Jun 30, 2011 | 09:38 AM
zwede's Avatar
zwede
Very common problem. The plastic alignment tool is not precise enough. The tip of the input shaft is hitting the side of the pilot bearing/bushing.
Your plan to depress the clutch is the right one. With the clutch pressed the tranny will slide in.
Old Jun 30, 2011 | 10:01 AM
Gordonm's Avatar
Gordonm
I have done it many times this way myself. Depress the clutch and wiggle it in there. I use two studs so thetrans has something to rest on as it slides it. It helps guide it in.
Old Jun 30, 2011 | 11:42 AM
TPIShark's Avatar
TPIShark
Thanks Guys. Much appreciated!
Yeh, it's close enough where the bolts will actually start halfway, so perhaps I'll use those to aid in alignment. I have both the trans and the engine supported on scissor jacks, and they are lined up well.
Old Jun 30, 2011 | 12:09 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I had the same thing happen when I installed the TKO-600 in my car.
I agree with Zwede, the cheap plastic alignment tool included in my kit left the disc off center enough to cause the trans to come up short. Recentering the disc allowed the trans to finally go in. Be very careful about using the trans to bell housing bolts to pull the trans in. If the trans is still hung up, you could crack an ear off the trans.
Old Jun 30, 2011 | 01:07 PM
TPIShark's Avatar
TPIShark
Thanks Mako. Yep, I would never actually use the bolts to pull it in, just loose to get it square. I might not even do that, at least at first.
Old Jun 30, 2011 | 08:50 PM
trw's Avatar
trw
Use the second person method. The problem is the plate, not the trans.
DO NOT TRY TO PULL THE TRANS IN WITH THE BOLTS
It will be a heartache that you do not need.
To Tremec install. ALMOST in. Thoughts?
