AutoX Tires
Old Jul 5, 2011 | 04:03 PM
silver79's Avatar
silver79
Default AutoX Tires
Since I got the auto cross bug, I would like to have a set of better race tires on my Rally wheels for the race days, I would like to keep the size of 255/60/15 or a bit larger in the rear. Any suggestions about brand and size of course any recommendations are appreciated
Old Jul 5, 2011 | 04:07 PM
Gordonm's Avatar
Gordonm
The 15 inch tire is never going to perform as well as a 17 or 18 inch tire. That being said there is not much in the way of performance tires for a 15 inch rim. There just is not that much call for a 15 inch tire anymore. Are you looking for a slick racing tire or a good street tire.
Old Jul 5, 2011 | 04:20 PM
SteveG75's Avatar
SteveG75
Avon CR6ZZ
http://forums.corvetteforum.com/c3-t...von-cr6zz.html
http://forums.corvetteforum.com/c3-t...ay-report.html
Old Jul 5, 2011 | 05:54 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Old Jul 5, 2011 | 06:01 PM
eagle275's Avatar
eagle275
about 15" tires - I was recently going to purchase a Michelin "V" - rated tire in 225/60/15 Pilot® Exalto® A/S
Ultra-High Performance Sport http://www.michelinman.com/tire-sele...s/tire-details
Still considering 17's.
Old Jul 5, 2011 | 07:01 PM
TheSkunkWorks
For AX'ing, the OP needs as much footprint of soft compound rubber as he can get on the ground. 225's are on the skinny side for 8" wide rims and in a 60 series would only be ~25.6" diameter. The Avons mentioned are probably the best performing road legal tire available today for 15" rims, but 17" or 18" wheels would certainly open up many other choices.
Old Jul 5, 2011 | 08:46 PM
silver79's Avatar
silver79
I was considering 17" but what about weight, I think that a 17" combo will be much heavier.
Old Jul 6, 2011 | 12:37 AM
GUSTO14's Avatar
GUSTO14
Just keep in mind that anything but a 15" tire will kick you out of a stock class in the SCCA...
Good luck... GUSTO
Old Jul 6, 2011 | 11:35 AM
69autoXr's Avatar
69autoXr
Steel rally wheels are about the heaviest you can get.
If you want to stay on 15's you're choices are limited, but Hoosier makes the Street TD sports car DOT bias tires in 245/45, 245/60, and 275/60. They're decent tires but are not as fast as Hoosier A6's or Kumho V710's (but no good 15" sizes in those tires). Hoosier also has 15" choices in non-DOT bias (Vintage racing tires) if those interest you. I believe they have some 15" tires on closeout, check their discontinued inventory.
Old Jul 6, 2011 | 03:53 PM
silver79's Avatar
silver79
I’ve been reading a bit about autox they say that 70% is driver ability, 20%tires and 10% set up..... So I will focus of ability for now. I have Firestone Indy 500 what pressure would you suggest for a beginner, is it possible that at 34lbs R and 32lbs F that my car becomes darty unstable and at 28 it tracks better?
Old Jul 6, 2011 | 04:50 PM
69autoXr's Avatar
69autoXr
I'd suggest setting the rears a few PSI lower than the fronts. You can try chalking your tires at three points around the circumference where the tread meets the sidewall, and adjust your pressure according to the wear on the chalk marks. If there is no wear on the marks, lower the pressure; if there is wear, raise the pressure.
Old Jul 7, 2011 | 09:41 AM
silver79's Avatar
silver79
Nice advice I will try next week
Old Jul 7, 2011 | 12:11 PM
76stingracer's Avatar
76stingracer
Hoosier also makes the R6 and A6's for a 15" rim. The 245 fit square on a 8" wide rim. Ran them for years. I am currently running the 275-60 on a 15x8 rim. I normally run the R6's Hoosier. I get a little more life out of a set of R6's than A6's.
Old Jul 7, 2011 | 01:18 PM
silver79's Avatar
silver79
what do you think of Mickey Thomson Street ET wheels
Old Jul 7, 2011 | 10:50 PM
vettehardt's Avatar
vettehardt
I currently run 84-87 style 16" wheels on mine because the tire selection in 15" is almost non-existent. I run Kumho Victoracer V700s or Kumho ECSTA V710 in 265/45/16 size. This combo with the adapters is still lighter than the 15X10" wide circle track wheels we used to run.
Hoosier A6 and R6 do have a 275/35/15 that would work on your 15" wheels, but those tires are $266 a piece at Tire Rack. You would also most likely have to trim some of your fender lips to keep from rubbing.
In the near future I am planning on stepping up to 17" wheels because the tire choices are so much greater. I could even end up running a cheaper tire on the 17" than what I do on the 16" wheels. On that note, anybody have a set of 17"X8.5-9.5" wheels for sale really cheap (looking to stay under $250)? Paint condition or curb rash doesn't matter, just that they are straight and will hold air and fit a 5X4.75" bolt pattern.
Old Jul 8, 2011 | 08:06 AM
silver79's Avatar
silver79
Old Jul 8, 2011 | 09:35 AM
76stingracer
MT Street ET rims or tires? Both are for drag racing. The tires have a very weak side walls that allow them to wrinkle for drag racing, something you don't want in autocross. The rims may be to weak to handle the side forces also. Most drag racing rims are, just that, only made for drag racing.
Old Jul 8, 2011 | 10:52 AM
silver79's Avatar
silver79
thanks i meant tires and that is what i thought
To AutoX Tires
