wiper door actuator
Old Jul 9, 2011 | 06:00 PM
zamps69's Avatar
zamps69
Default wiper door actuator
I have checked in previous posts if these can be rebuilt. Does anyone know if they can?
I have a 69 and the problem is if both inlet tubes are closed the shaft can still be moved in and out by hand without much effort.
Should there be much resistance because when there is vacuum the shaft moves but I can stop the shaft moving with very little force.
Old Jul 9, 2011 | 06:34 PM
knockbill's Avatar
knockbill
the rubber piece teh shaft comes thru could be split,,, that rubber piece is available, if needed... if not, teh diaphrams in teh can are bad...
mrvette's Avatar
mrvette
Sounds like you have a bad diaphragm in there.....new canister....
I have a used one off my '72 if interested....I have to look...
Old Jul 9, 2011 | 07:05 PM
Alan 71's Avatar
Alan 71
Hi z 69,
The actuators can be rebuilt but the cost is close to the price of a reproduction.
You can try replacing the front plug; they have sometimes gotten dry over the years and may leak a bit.
Regards,
Alan
Which shape actuator do you have?
Old Jul 9, 2011 | 07:30 PM
mrvette's Avatar
mrvette
Originally Posted by Alan 71
Hi z 69,
Regards,
Alan
I think 68 maybe early 69 looked like soup cans, the later through my '72 looked like the headlight canisters....
Old Jul 9, 2011 | 08:27 PM
zamps69's Avatar
zamps69
That rubber piece I thought is more a dust/dirt seal.
Thanks for the offer
The one I have is like a big soup can.
Might be easier to source a new one as I'm from down under
Thanks John
To wiper door actuator
