One piece rear clip alignment
Old Jul 16, 2011 | 06:32 PM
zwede's Avatar
zwede
"Build up the fender"??? No, that will be a disaster. If you need it to be higher you need to cut the panel along where the factory would have put the bonding seam, raise the top and then bond it back together. Put a bonding strip behind it and fill the gap with resin & mat.
Old Jul 16, 2011 | 07:48 PM
Alan 71's Avatar
Alan 71
Hi b,
I thought this might help with the contours.
Regards,
Alan
Old Jul 16, 2011 | 10:41 PM
Blain's Avatar
Blain
I don't think you see the problem. The fender doesn't need to be raised. The fender crown line hits the door perfect.
Originally Posted by Alan 71
Hi b,
Regards,
Alan
Thanks Alan. What do you see in the angle I show on the previous pics? The green vert seems to have the steep angle off the crown down to the deck lid.
So after all this I decided to set the lid with the door and build up the inside edge to match. I hope I don't have the "disaster" Zwede warned me about. I think it looks good. I can move on. Stalled here too long.
I'll post another pic tomorrow after smoothing it out. Geez, Zwede "disaster" is going to keep me up tonight!
Blain
Old Jul 16, 2011 | 11:18 PM
zwede's Avatar
zwede
"Disaster" as in trying to shape that compound curve nicely. It will be tricky. Hope it works out for you.
Old Jul 17, 2011 | 12:01 AM
Blain's Avatar
Blain
I found that on the front fenders where the ZL flares where bonded. Seems like I work them for hours just to be right back where I started. A flat spot somewhere in the compound area.
Might be frustrating but the satisfaction once you "get it" is worth it.
Blain
Old Jul 18, 2011 | 11:58 PM
Blain's Avatar
Blain
Roughed in. Ready for glazing compound. I Like how it blends.
Hey Alan-do you have a picture of the door closed?
Blain
Old Jul 19, 2011 | 08:47 AM
RobRace10's Avatar
RobRace10
If you are trying to do this without the body on the frame, you are making a big mistake. Here is my body on the dolly. If you notice the door gap, once I put it back on the frame it came right back in. The convertible bodies flex and until it is pulled down on the frame mounts you will not know where you are at.
Old Jul 19, 2011 | 02:48 PM
Blain's Avatar
Blain
I understand, but I build my dolly with front and rear supports. Used factory frame measurments to adjust the mounting points on the dolly to square it up. Any discrepancy now should be within shim distance.
Of coarse I may be wrong. Time will tell.
Robrace10; Nice ride! What are the wheel/tire sizes? Just the look I want for my other car. ('74 coup)
Blain
Old Jul 19, 2011 | 03:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Blain
Beginning to look pretty good. Keep an eye on the decklid/fender gap. 3/16th all around would be nearly perfect.
Old Jul 19, 2011 | 05:36 PM
RobRace10's Avatar
RobRace10
Blain
The fronts are 17X8 4”BS (Tires 245/45) and rears are 18X10 5.5”BS (Tires 275/40)
