Rear Wheel Bearings
Old Jul 12, 2011 | 12:16 PM
Lon Wayne's Avatar
Lon Wayne
Default Rear Wheel Bearings
Dam got in here the bearings look better than the ones I bought .
Has anyone just repacked and replaced there wheel bearings????
Old Jul 12, 2011 | 01:10 PM
Rally68's Avatar
Rally68
what is your method for inspecting the bearings? the rear bearings are press-fit to the spindle; in order to gain access to the outer bearing to pack it, you would have to press or hammer the spindle out of the housing, which ruins your inner bearing.
I have heard of people drilling and tapping the middle of the housing for a grease fitting (or two), but I wouldn't do it. In fact, I'm willing to bet that the folks who service and rebuild these units for a living will tell you that the only way they can be properly lubed is by disassembly of the unit...you don't want to take a shortcut here
Old Jul 12, 2011 | 01:17 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Yep that is what I thought pull and re-place.
Shizzle just had my rear end all apart half shafts off doing yokes and did not do the wheel bearings at the same time.Only the drivers wheel seems to have any play.the pass is tight.
Old Jul 12, 2011 | 04:30 PM
Rally68's Avatar
Rally68
it is a big job but pretty straightforward. let me know if you are going to do it yourself, i still have a spindle knocker and the spindle setup tools, plus fixtures I made to hold the housing in a bench vice while you torque it for set up, to press on the bearings, etc. i'd sell ya that stuff cheap if you want it
Old Jul 12, 2011 | 10:37 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
Wow I can tell by your shop and tools you know what your doing thanks for the come back. I jacked the car up tonight and shook the tire its not the wheel bearings its the trailing arm bushings. the arm moves(other than up and down) and the other side does not what do you think.
and how much is cheap?? on your tools, ill need to do the bearings at some point and next year im building a pole barn. so ill be needing tools .The tire does not move side to side just up and down.
Old Jul 13, 2011 | 08:36 AM
Rally68's Avatar
Rally68
Thanks, I wish that were true...my wife tells people I am an amatuer mechanic and a professional tool collector.
On the tools, I was thinking $100 bucks. I know Duntov used to sell them for $200 and then buy them back for $120, if they still do that it's probably a better deal for you
Old Jul 13, 2011 | 11:27 AM
7T1vette's Avatar
7T1vette
Why were you even considering changing them? Just because of age? If there is no significant 'slop' in the rear bearings, I would just leave them alone. Why screw with something that is working just fine? (especially with the most difficult part of the entire C3 vehicle) Put the new bearings in storage for when you really need them.
To Rear Wheel Bearings
