need rear suspension help
Old Jul 16, 2011 | 06:04 PM
karr107's Avatar
karr107
Navigator
Default need rear suspension help
hi all i have just purchased a 1979 vette, it needs alot of work but it runs well and drives ok except for the rear suspension. i have alot of rattles and noises when i go over bumps and it sounds like im pulling a empty trailer, the spare tire holder was empty and the rear of it was zip tied up so i removed the whole thing to replace hardware that's when i got a good look at the rear spring??? i know its not stock but is this thing supposed to be better? i think the ride quality from the rear is poor, has anyone seen a spring like this?
it looks like a one piece carbon fiber spring but im not sure any help, or opinions on this thing would be greatly appreciated
Old Jul 16, 2011 | 07:27 PM
doctorgene's Avatar
doctorgene
Yes Sir; In my opinion, I think the composite spring, is one of the best things you can do to your car. Yes it is probably an aftermarket spring. G. M. started installing them in the 1981 automatic cars. In 1982 they were installed in 20K cars, with only 5K with the heavy suspension having the steel spring. In 1984, all the springs were in Composite material. I think you need to look at all the spring mount bushings, then the trailing Arm bushings, & at the U- joints on the 1/2 shafts. Last but not in the least, your exhaust system looks like it might be the main problem. Also there needs to be a heat shield between the spring & the exhaust system, I can't tell if you have one or not. Have a great day. Gene
Old Jul 16, 2011 | 08:45 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Hard to tell in the pic, but that spring seat doesn't look right. Looks like the insulator or something is pushed out on the top left of the mount and the right side bolt doesn't look like it's in all the way. Or the bottom plate is bent.
Old Jul 16, 2011 | 09:02 PM
billcarson's Avatar
billcarson
listen to what the dr. says.do something with that exhaust before you start dragging around plastic bags.
Old Jul 16, 2011 | 09:06 PM
johnmb's Avatar
johnmb
Agree...check those bolts thru the bottom plate. Also look at the bushings in the sway bar ends
John
Old Jul 16, 2011 | 09:10 PM
dgood's Avatar
dgood
That spring looks shot. There should be more of an arch to it and the center bushing does not look like mine. Mine has a big square rubber bushing that goes from the bolt on the left to the bolt on the right. one big piece. Also, pull the tires and check the brakes and I bet you could use a new pair of KYB shocks in the back.
I think your differential is leaking also, that is what is on the drivers side exhaust pipe it looks like. Make sure you have fluid in there.
Old Jul 17, 2011 | 12:51 AM
karr107's Avatar
karr107
Navigator
good eye, diff not leaking i just got done changing the diff oil and some leaked out of the fill plug when it was full, ty for all the responses looks like i have some work to do
Old Jul 17, 2011 | 01:03 AM
njfl's Avatar
njfl
I don't think your spring is shot as composite springs really do not weaken over time, they just crack or otherwise casostrophically fail (which happens very rarely by the way). I agree that the arch is less than I would expect (less than mine too). I suspect that someone used the stock (short) length bolts at the ends of the spring. This may be giving you a harder than expected ride with little spring action.
Old Jul 17, 2011 | 12:38 PM
karr107's Avatar
karr107
Navigator
yea i have been searching around the internet i am very interested is the shark bite coil over setup, i know my car is not worth much so i dont know how much money i want to put into it, but i do know i would like it to ride better
Old Jul 17, 2011 | 01:16 PM
billcarson's Avatar
billcarson
we must stop saying that these cars are not worth much and their value will go up.some would like everyone to believe this so they can get more for their cars.make it as good as you can and only change whats defective and you won't loose your investment.good luck
Old Jul 17, 2011 | 02:18 PM
dgood's Avatar
dgood
Karr, I put KYB shocks all around and noticed a big difference in the ride. Over the last couple of years I have replaced all the bushings and shocks and ball joints in the front. On the rear I have only replaced the spring bushings (I have a composite spring) and the shocks. Rides like a dream almost. Could use some bigger sway bars in the front and possibly put one on in the rear.
I tried the Monroe shocks at first and they made my car ride similar to a dump truck. KYBs are not that expensive and are good for the ride.
If your tires are old or bad, that can effect your ride also. There has been some discussions on here about date codes on tires and just because they look good, does not mean they are safe.
Old Jul 18, 2011 | 12:45 PM
karr107's Avatar
karr107
Navigator
so i guess i should start with shocks and a bushing kit then? i still dont like the way that spring looks tho dose anyone have a pic of how theirs looks? i did a search and cant find any good pic of a car on the ground and how the spring should look with the weight of the car on it
Old Jul 18, 2011 | 02:33 PM
jb78L-82's Avatar
jb78L-82
Correction! The fiberglass composite rear spring first appeared in 1980 on base suspension cars and was standard on all base suspension 1981 corvettes. The 1980/81 corvettes with the sport suspension had the 7 leaf steel spring. GM probably used the composite spring on the base suspension cars first in 1980/81 to hedge their bets on this new technology before offering on the sport suspension and all cars in 1982 (I thought at least). The steel spring disappeared after 1981. Hope that helps!
Old Jul 18, 2011 | 02:44 PM
Mike Ward's Avatar
Mike Ward
Looks typical to me..............
What are you seeing that's got you worried?
Old Jul 18, 2011 | 03:53 PM
doctorgene's Avatar
doctorgene
Yes Sir; Thanks jb78L-82, Jeff, I knew it was something on that order. I appreciate you getting the info. correct. Have a great day. Gene
Old Jul 18, 2011 | 05:19 PM
karr107's Avatar
karr107
Navigator
spring looks too flat no? i don't know what it is suppose to look like on a corvette but leaf springs i have seen have more of a arch to them? that's why i was wondering if any one had a pic of theirs
Old Jul 18, 2011 | 05:51 PM
Gordonm's Avatar
Gordonm
Here is one side of one.
To need rear suspension help
Old Jul 18, 2011 | 08:15 PM
karr107's Avatar
karr107
Navigator
well i defiantly see one difference, looks like mine has a gap top and bottom where the spring mounts in the middle to the diff, and bty very nice and clean under your vette wish mine looked that good lol, but i guess the arch is about the same on mine as yours will have to look into why there is a gap, and where to get a heat shield for it
Old Nov 9, 2011 | 11:08 PM
Mark Hawkins's Avatar
Mark Hawkins
quick question if I may ask. I have an 81. You have given me some good answers lately. Thank You. New question. I'm in the middle of searching for some pictures on how I go about replacing my rear leaf spring bushings. I purchased the kit rear spring end kit from Mid-America along with the competion strut rods you recommended. If you have any known post on the forum, that would be great. Thanks so much.
Mark
Old Nov 10, 2011 | 12:10 PM
doctorgene's Avatar
doctorgene
Mr. Jeff, In 1982 they sold 5,457 Gymkhana Suspension set up cars. Where are you getting your Info. that 81 cars were the last year. I'm not doubting your info. I would just like to know more info. on the 82. If they used the Composite Spring, on the Gymkhana Suspension in 82, I wonder what the weight of the spring was rated at?
