Alumiumn Heads Question?
Old Apr 26, 2002 | 07:48 AM
SprintCarDriver's Avatar
SprintCarDriver
Default Alumiumn Heads Question?
Just got my heads in yesterday and have a few questions.
1. I noticed a little flasing on some of the Exhast ports. Is it alright to remove this with a grinder?
2. I was told to use a sealeant on the rocker arm studs. Will permatex be ok for this?
3. Will my ARP head bolts work with the Alum. Heads? Corosion? (Steel/Alum)
4. Anything Else I might need to know before, during or after I put these on?
Thanks..
Old Apr 26, 2002 | 11:38 AM
zwede's Avatar
zwede
Default Re: Alumiumn Heads Question? (SprintCarDriver)
1: Yep, removing it is fine.
2: I use RTV black. I'm sure permatex is ok also.
3: ARP steel bolts work fine as long as they have the hardened washers. Without washers you will gauge the aluminum.
gearheadz's Avatar
gearheadz
1. IMO OK to remove excess flashing only, don't alter the port wall contour/size
2. Permatex OK.
3. Steel bolts OK. Not aware of any alternative anyway ... besides titanium or the like.
4. Follow torque sequence & specs. Use head gasket that won't score head to block surface. Apply small amount of lube under bolt heads to avoid scoring head surface and to obtain accurate torque reading. I think ARP bolts are washerless.
Mark
[Modified by mdsmith, 10:39 AM 4/26/2002]
Old Apr 26, 2002 | 11:46 AM
SprintCarDriver
Default Re: Alumiumn Heads Question? (mdsmith)
Thanks for the replies. I was thinking of using a fine file to remove the flashing and be real careful. :eek: The ARP bolts that I have do have a washer. I also have to use antiseize on anthing that screws into the heads also correct? :yesnod:
Thanks again. Maybe I can get pictures by monday. They sure do look :cool:
gkull's Avatar
gkull
Use a copper crush ring head gasket for aluminum heads. I put thread sealer on every head bolt or stud. Invest in ARP header studs and install them with anti-seize. Never take a chance on stripping out a threaded hole.
Old Apr 26, 2002 | 11:48 AM
SprintCarDriver
Default Re: Alumiumn Heads Question? (gkull)
Felpro's blue Head gasket wont work? Why copper as oppose to the Alum. Ring?
Fevre's Avatar
Fevre
My ARP's came with washers but there may be diff kinds/apps.
I used ARP thread sealer for my head bolts and rockers studs.
Old Apr 26, 2002 | 11:49 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The ARP bolts that I bought have a thick washer under the head. I used the black Permatex RTV.
Old Apr 26, 2002 | 11:50 AM
SprintCarDriver
Default Re: Alumiumn Heads Question? (Fevre)
I also have the ARP sealer. I was told that the torque was 60 to 65 on the rocker arm studs, is that correct?
Old Apr 26, 2002 | 01:09 PM
gkull's Avatar
gkull
The Fel_Pro you want to use is part number FPP-1010 in the Summit Racing cat.
I'm using something simular, but I got it for a 4.030 bore to keep compression up.
Old Apr 26, 2002 | 03:16 PM
SprintCarDriver
Thanks for the heads up on the gasket. Apperently the heads require a :eek: Performance Gasket :eek: for both the heads and intake. Call my supplier and the researched and laid out the required gaskets. Still on for tomorrow..
that saved me from a lot of greif :yesnod:
Old Apr 26, 2002 | 03:21 PM
Alwyn678's Avatar
Alwyn678
[/QUOTE]
Nice Pic......... :yesnod:
Old Apr 26, 2002 | 06:11 PM
LeAnn82Collector's Avatar
LeAnn82Collector
I think the rocker arm stud torque is around 40 to 45 foot pounds.
I had Edlelbrock aluminum heads, and I blended and smoothed out the exhaust port openings, and blended the intake openings. They were CNC'd in only part of the way. Use washers under the head bolts, and use a sealer on them. Also, check the position of the guide plates after tightening the rocker studs.
[Modified by LeAnn82Collector, 10:12 PM 4/26/2002]
Old Apr 26, 2002 | 07:41 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Default Re: Alumiumn Heads Question? (LeAnn82Collector)
My wife really knows her stuff, eh?
Old Apr 26, 2002 | 08:24 PM
LeAnn82Collector
Default Re: Alumiumn Heads Question? (corvgreg)
I don't understand a word I said... :D
To Alumiumn Heads Question?
