Engine guys - Plug gap importance
You do need to be able to supply voltage to jump that spark and that starts at the coil. In general, it is dependent upon the entire secondary electrical system, including the wires to ensure that the voltage is properly distributed to teh plug.
Someone mentioned misfire. That is correct, that you do not want misfire. To reduce misfire, use an MSD or similar Multiple Spark Discharge (more then one spark each time). This helps a lot with wider gaps.
For the op, err on the side of a smaller gap. You'll get a better performing engine for everyday use. Then, play around and gradually make it a little wider if desired.
Also the reason for a small plug gap on a mag is because of the slow rpm's produced at cranking speeds. after an engine is running at 1000 or so rpm a mag will fire a very larger gap, like .200 or better, but then you can't start the engine like that!
There are a lot of things that can effect the plug gap. The higher the cylinder pressure, the more voltage it takes to jump the gap. The higher the rpm, the more voltage drop most ignitions will have. In both of these cases you will have to close the gap down to get the job done unless you can increase the voltage output. High RPM, high boost turbo applications can need as small as a .012" gap, even with high output race ignitions. Increasing the gap increases the voltage it takes to jump the gap. Voltage is what jumps the gap. On a low RPM, low compression street engine with a high output ignition, the gap can be pretty large. It will increase the voltage output from the coil and provide a larger spark surface to fire the air fuel charge. As someone has stated, this helps with lean AFR applications and will help to a lesser degree with richer AFR settings.
Amperage is what creates the heat. The more amperage the hotter the spark. Spark duration is also important. Look up specs on racing ignitions and they will have the milliseconds of spark duration. The longer the spark duration, the more chance of getting a more complete ignition of the air fuel charge. In a perfect world you increase the voltage, amperage, and spark duration all at the same time, however, it's not that easy. Generally working within the realms of a street ignition, increasing voltage usually is accompanied by a loss of amperage. It's a balancing act.
One down side to running as wide of a gap as you can get away with and not have misfire is that you are asking the coil to produce closer to it's maximum output for more of its operating time. You will stress the ignition and a shorter life is possible.
P.S. I'm not a fan of ethanol for a number of reasons.
LP
