77 Thermostat Question
Old Jul 26, 2011 | 12:30 AM
bruisedknuckles's Avatar
bruisedknuckles
Default 77 Thermostat Question
77 Small Block.
Replacing the water neck and figured I would change the thermostat as well. While looking for a thermostat, I see a bunch of options.
1. Corvette Thermostat, 160°
2. Corvette Hi-Flow/Hi-Performance Thermostat, , Robertshaw, 1955-1991
3. Corvette Thermostat, , Hi-Flow, Robertshaw, 1955-1991
Which one do I use? Is it better to use one over the other? Why would I use 180° over a 160° and is there an advantage to a Hi-Flow?
Thank you.
-D
Old Jul 26, 2011 | 01:14 AM
7T1vette's Avatar
7T1vette
If you have a stock cooling system, I would recommend a 180* stat designed for the small block Chevy engine. Your original T-stat is a 195* unit, but that was strictly for emissions reasons. The Chevy SB was designed to run at 180* for best all-around benefit. If you don't have a "Hi-flow" water pump, you don't need a "Hi-flow" thermostat. Buy a good brand name unit. You can save a few dollars buying the AutoZone 'special'...but your car deserves better than that.
Old Jul 26, 2011 | 08:11 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Stick with a 180 stat as said above.
Old Jul 26, 2011 | 09:34 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Spend a little extra and get the Robertshaw 180*, if I remember correctly its a fail open T-Stat. You will still have cooling if it ever fails to prevent damage to the engine.
The Robertshaw is one of the best on the market today.
Neal
Old Jul 26, 2011 | 09:49 AM
...Roger...'s Avatar
...Roger...
If your 77 is all stock and has all stock emissions items on the car , you will have to go with a 195.
Old Jul 26, 2011 | 09:53 AM
bruisedknuckles
Thanks guys, very helpful.
Neal, not sure if it is a fail safe, will check for sure. Any way to test if its working correctly (apart from damage to the engine)
-D
Old Jul 26, 2011 | 11:51 AM
Sigforty's Avatar
Sigforty
-D
Are you wanting to test the thermostat? If so just put it into a pot of water on the stove and see if it opens at the desired temperature.
Old Jul 26, 2011 | 11:53 AM
...Roger...
That's also a good thing to do with any brand new thermostat.
Old Jul 26, 2011 | 10:08 PM
chevymans 77
I have tested a few using this method along with a cooking thermometer to verify the opening temp.
Neal
Old Jul 26, 2011 | 11:08 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Originally Posted by 7T1vette
The Chevy SB was designed to run at 180* for best all-around benefit. .
Care to explain?
To 77 Thermostat Question
