81 hp gain
Old Jul 24, 2011 | 04:03 AM
MattCC81's Avatar
MattCC81
Default 81 hp gain
I have a stock 81 was wanting to figured a general hp gain.
I got a (not yet installed)
-600 Edelbrock Carb
-Edelbrock Performer Intake Manifold
-Comp cam kit. (Cam/Lifter, Valvetrain, Hydraulic Flat Tappet, Advertised Duration 268/268, Lift .454/.454, Chevy Small Block, Double Timing Chain, push rods)
-Headers Primary 1 5/8 3 inch coll going true dual
-350 Trans with 25 stall
Im taking all emissions egr off.
Trying to figure how much hp it will be at and if ill run into any problems.
Old Jul 24, 2011 | 05:09 AM
Ralphbf's Avatar
Ralphbf
Sounds like your off to a good start.
It must be nice to take the smog off a 1981.
What state are you in?
Here on the Left Coast it's 1975 1/2 or older.
Ralph
Old Jul 24, 2011 | 06:37 AM
gingerbreadman1977's Avatar
gingerbreadman1977
if you had a stock stall before than your 2500 is going to give you the best improvement.
all those parts wont give you any problems, just improvements . now search for some vortec heads or similar.
Old Jul 24, 2011 | 09:13 AM
qwank's Avatar
qwank
is the stock ECM still hooked up and working? if it is, you will need a non computer controlled distributor to run the Edelbrock carb.
If it was me, I would use the stock carb, unless thats a huge cam that will set the CEL.
Old Jul 24, 2011 | 11:11 AM
damoroso's Avatar
damoroso
It's a really nice start, be prepared though. That engine has 8.2:1 compression and the heads are designed for emissions not necessarily performance. qwank is absolutley correct, the CCC distributor will also limit what you've got planned. If at all possible, you might want to consider heads too, or waiting until you can include the heads with the package. As I'm sure you know, everything has to work together and unless you can take advantage of the cam, intake and exhaust (via good flowing heads and valves) you might be frustrated....
Old Jul 24, 2011 | 11:18 AM
7T1vette's Avatar
7T1vette
Good luck with your efforts. I'm trying to figure out how removing a 750 cfm Q-Jet and installing a 600 cfm [antiquated design AFB clone] Edelbrock is an improvement, though.
Old Jul 24, 2011 | 11:27 AM
Ganey's Avatar
Ganey
You will see a dramatic improvement somewhere over 3000 & up (you)
due mainly to cam & exhaust. Needs better heads. If it was a fresh build on dyno under 300hp maybe 275 just to give you a no. & w/ new heads over 300HP.
Old Jul 24, 2011 | 11:37 AM
rcread's Avatar
rcread
That carb is going to slow you down. I would recommend the Quadrajet or a Holley over the Edelbrock. Either will get you better performance and MPG.
Old Jul 24, 2011 | 11:41 AM
Ganey's Avatar
Ganey
CARBS Tests TQ/HP
http://www.corvettefaq.com/c3/carbcomparo.htm
Old Jul 26, 2011 | 12:00 AM
MattCC81's Avatar
MattCC81
Texas, but im not concerned emissions I just want it off.
From what I read the direction im in seems to be good. I wanted to check if anyone had any problems installing these parts just so I could get a heads up.
Also if anyone knows some detailed corvette cam swaps that they could lead me to that would be great.
Old Jul 26, 2011 | 09:12 AM
SIXFOOTER's Avatar
SIXFOOTER
Your plan has a flaw, your planning on installing a smaller carb than what is on there now?
Thats not going to make much HP. You should already have a good intake on there, the 2101 is a good unit. The cam kit and dual setup will do more than anything else to wake it up. I would save the $ from the carb and intake and put it in heads, AFR185 or the like.
Old Jul 26, 2011 | 03:50 PM
MattCC81's Avatar
MattCC81
Well at this moment im trying to get all emissions off first, and for the carb that was the one recommended over the holley 670 because its a daily car. And as for the heads Im planning to do it after the distributor
Old Jul 26, 2011 | 04:48 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree,..keep the 750 Q-Jet.
And agree again. There some very affordable aftermarket aluminun SB heads that alone, should provide a 50 HP increase.
Good luck!
Old Jul 26, 2011 | 05:22 PM
qwank's Avatar
qwank
you can get an EGR blockoff plate for the stock intake.
Old Jul 27, 2011 | 09:51 AM
81$$pit's Avatar
81$$pit
600 CFM is fine up to 300 HP. I had a 600 Edel and changed it for a 600 Holley on my 79 I had 10 yrs back and it ahd headers true duals, flat top pistons and a big cam plus upraded HEI.
I got pretty good perf out of it and good gas mileage.
That being said, if I had better heads as well I would have wanted at least a 670 Avenger. They are very easy to tune to your mods as well just send Holly support an Email with your combo and they will tell you what seconday springs to use and squirter etc..
To 81 hp gain
