72 LT1 head numbers help
Old Jul 28, 2011 | 10:10 AM
JBLT1's Avatar
JBLT1
Default 72 LT1 head numbers help
Calling all 72 LT1 owners and or Vette gurus. I have a 72 LT1 with 44k original miles. Every number on this car checks out with the possible exception of the heads. The car was built in July 72 (526171), block date is June 17 72, heads date June 9 72, so far so good. The heads however are 993 heads with screw in studs, push rod guide plates and LT1 spec valves. My question is, could these still be correct since this was the last month of the last year for the LT1 CORVETTE? Maybe they ran out of 916s and 487s and modified some 993s on the line? Any thoughts or experience with this situation would be appreciated.
Old Jul 28, 2011 | 10:35 AM
arcticcatmatt's Avatar
arcticcatmatt
How do you know what the heads date? I have a 71 non LT1 car that came to me with LT1 heads. Casting numbers on them is 3973487 . Research tells me thats the 75cc heads that came on 71-72 350sbc LT1 cars.. dont' know if this thread helps you or not http://www.hotrodders.com/forum/rook...ion-43799.html
Old Jul 28, 2011 | 10:51 AM
Mike Ward's Avatar
Mike Ward
It's not rare to see part number change overs that don't line up exactly with model year transition. Without being familiar with any physical differences between the two casting numbers that would prevent them form being interchangeable, I would say it's very possible that the 993s that were to be introduced for the '73 MY ended up on your car.
Old Jul 28, 2011 | 11:02 AM
JBLT1's Avatar
JBLT1
Date code on heads is "F 9 2" June 9 1972.
Old Jul 28, 2011 | 11:05 AM
JBLT1's Avatar
JBLT1
Makes sense to me also, even though they would've had to have been modified for the LT1.
Old Jul 28, 2011 | 11:18 AM
Mike Ward's Avatar
Mike Ward
That casting number was used on both version of the SBC in '71 not just LT1.
Old Jul 28, 2011 | 12:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My NCRS Specifications Guide says the 993 heads may have been used on the 72 base engine cars and says usage is unverified.
Have you posted on the NCRS Forum?
See if you can find Rowdy Rat. He knows his way around LT-1s.
Articcatt: sent you a PM.
Old Jul 28, 2011 | 02:13 PM
Alan 71's Avatar
Alan 71
Hi JB,
According to the information I'm looking at the 993 head casting is listed as a possibility for 1972 LT-! engines.
Regards,
Alan
Old Jul 29, 2011 | 05:31 PM
JBLT1's Avatar
JBLT1
Thanks Mike, I'll keep an eye out.
Old Jul 29, 2011 | 05:34 PM
JBLT1's Avatar
JBLT1
Originally Posted by Alan 71
Hi JB,
Regards,
Alan
Thanks AL, still waiting for my 72 NCRS guide to show up. For some reason it's a hard one to get a hold of.
John
Old Jul 30, 2011 | 01:30 PM
Vetteaddiction's Avatar
Vetteaddiction
John,
The data I see on the 993 head shows 1.94/1.50 valves, vs the normal Lt-1 head, 3973487x which has 2.02/1.60.
As a comparison I have a late June build Lt-1 also, with one 487x head, dated Mar 7, and a replacement head on the other side. The other head is a 333881, with 2.02/1.60 valves, screw in studs, and guide plates.
http://outintheshop.com/faq/casting/heads.html
Hope this helps,
Chris
Old Jul 30, 2011 | 02:23 PM
wallifishrmn's Avatar
wallifishrmn
According to my NCRS 1970-72 tech info manual & judging guide.
Base engine & LT1
1971: 3973487
1972: 3973487 X
1972: 3998916
1972: 3998993
X indicates that an X-casting foundry proofmark appears after the seven digit casting number on later 1972 cylinder heads.
On 350 heads, the driver side head casting number can be seen if the oil fill cap is removed. On LT1's the push rod guide plates are also visible.
Hope this helps.
Old Jul 31, 2011 | 10:15 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
The 993 heads are possible, but it is certainly not the norm.
Most of the heads on 1972 LT-1 Corvettes that I've seen over the years are either 487 or 487x (my own mid-June car has the 487X heads). Still, if the casting dates are in line with the rest of the engine, they most certainly could be the original heads.
What are the casting dates on these heads?
Regards,
Stan Falenski
Old Jul 31, 2011 | 10:40 AM
Chuck72's Avatar
Chuck72
My '72 Lt1 is an April 27 build, 487x heads.
Old Aug 3, 2011 | 01:04 PM
JBLT1's Avatar
JBLT1
Regards,
Stan Falenski
John
Old Feb 15, 2012 | 10:13 PM
Dancingbear's Avatar
Dancingbear
6th Gear
Default casting Numbers
Chuck,
Mine is April 25, 1972 (LT-1 + A/C). I understand that it should have 487x heads, but is the block supposed to be a -010 or -014?
What is your block date code?
John
To 72 LT1 head numbers help
