Quick master cylinder question
Old Aug 1, 2011 | 09:07 AM
...Roger...'s Avatar
...Roger...
Originally Posted by BillyTz06
Yes , the m/c rebuild kit is here but I didn't pick it up because the m/c held pressure with the plugs in the ports. I thought the concensus was that the m/c was not bad as long as the pedal was hard with the plugs installed.
The plug test is a decent initial test but it doesn't say with 100% certainty the master is good. A follow up would be to let the master sit with the plugs in and then try applying very very slow force and see if you can get the piston to move in.
You could also still have air in the system,are you using the pump up and bleed method , gravity or a Motive type.
You know you might be better off going to Autozone and getting a 19.95 master and bleeding your system with it,if the pedal stays up you'll know the chrome master was at fault.
Where is your old master ?
Old Aug 1, 2011 | 09:19 AM
redvetracr's Avatar
redvetracr
are you bench bleeding on the car? or in a vise on a bench?
Old Aug 1, 2011 | 09:22 AM
BillyTz06's Avatar
BillyTz06
I did let the master sit for a day and a half with the plugs in it and still had the same rock hard pedal. I am using the pump and bleed method as I can't find a motive locally and have never had a problem with the pump and bleed method. I still have the old master cylinder so I will switch masters today and see what happens. This shouldn't be rocket science, there's only the master, booster, porportioning valve and calipers that move unless I'm missing something. I've bled the system so many times I don't see how I could possibly have enough air in the system to make the pedal go to the floor and not be able to pump the brakes up at all.
Old Aug 1, 2011 | 09:38 AM
...Roger...
If the old master worked putting it back on will rule out the master. The pump and bleed works well on other cars but can be touchy on C2s and C3s if you over pump.
Old Aug 2, 2011 | 05:01 PM
BillyTz06's Avatar
BillyTz06
I tried bench bleeding my old master cylinder but there was to much trash floating around and it was taking forever trying to flush it out so I decided to pick up the m/c rebuild kit that I ordered. I rebuilt my new chrome m/c, bench bled it , installed on the car, bled the lines at the m/c and proceeded to bleed the system. It was worst than before. Some fluid imeadiatly came out of the inner rr bleeder then stopped flowing. The rest of the bleeders on the rear were the same. Went to right front and a unusual amount of fluid came out. The left front was the same way. Bleed the whole system again and can hardly get any fluid out of the rear. So there the car sits. Im about at my wits end. Anybody got a very large caliper gun ....... no ,not for me .... the car. Where do I go from here?
Old Aug 2, 2011 | 05:28 PM
noonie's Avatar
noonie
Sounds like your have a new problem.
I would remove the combo valve, take it apart and clean it out with brake fluid and compressed air.
Old Aug 2, 2011 | 05:31 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Went through the exact same thing last year on a 68, and nothing worked. Turned out the calipers were sucking air on the upstroke, and not leaking fluid. New s/s calipers.....Fixt!
Old Aug 2, 2011 | 06:42 PM
knockbill's Avatar
knockbill
i agree,,, air is getting in some way, and the calipers are a good place to look,,, i have ss calipers on my 68, and find they still can get some rust and corrosion in them,,, teh springs and the bottoms of teh cylinders are either iron or steel, so, they corrode.... a little piece of rust will hold teh caliper seal open enough to suck air... i just went thru my calipers, and found some rust in them,,,, i'm using dot5, but the iron can still rust.....
Old Aug 2, 2011 | 09:02 PM
BillyTz06's Avatar
BillyTz06
I guess I'll spring for new calipers tomorrow. Hate to spend that much $$$ and not know that it will fix the problem but I built this car to drive and not be a boat anchor sitting in a garage. I'll look at the brake switch also. Just about the whole brake system will be new after I do this. Keep your fingers crossed.
Old Aug 2, 2011 | 09:17 PM
...Roger...
If your calipers are sucking air , if you gravity bleed air should come out of the bad caliper almost immediately after you open the bleeder.
If air is being draw in at the master cyl bore,you should be able to get air at the line fittings.
Old Aug 2, 2011 | 10:01 PM
noonie's Avatar
noonie
If you are getting lots of fluid out the fronts and a trickle out the back as you said in post #25, then your combo/proportioning/differential valve is tripped. It has to be recentered. That's at least half of your pedal travel right there.
If your master is truly as dirty as you said in post #25, then so is your combo valve. It would be wise to remove and clean it.
Before you buy new calipers, take them apart, they are likely already ss lined and can be rebuilt fairly cheaply with piston/seal kits. Check to see that they have the springs in them. This prevents them from sucking air with use of the master.
Internally, when the brake pedal is released, the pistons return causing slight neg pressure in the system and to prevent any wheel cylinders from sucking air, the pressure seals in the master have small orifaces behind them to allow fluid into the low pressure area and also top off the volume in front of the seal.
Any air entering the rear of the master should escape thru the inlet port into the rear reservoir.
Old Aug 2, 2011 | 10:38 PM
Peterbuilt's Avatar
Peterbuilt
Are you sure all the seals in the M/C are facing the correct way?
See post 11 by Duke94
http://forums.corvetteforum.com/c3-t...-cylinder.html
Old Aug 3, 2011 | 02:58 AM
  #33
c31980's Avatar
c31980
i run into same issue last year with my 80 ,,, switched for o-ring kit got it from eBay
problem solved
Old Aug 3, 2011 | 08:54 AM
  #34
BillyTz06's Avatar
BillyTz06
The master cylinder seals are installed correctly, thanks for the pictures. I'm sure they will help someone else that is doing a rebuild. I will buy new ones.
Old Aug 3, 2011 | 12:47 PM
  #35
BillyTz06's Avatar
BillyTz06
I took all 4 calipers off and found one piston in right rear completely stuck, pulled the seal and found major corroison . Some of the pistons in two of the fronts were not releasing fully so I bought 4 new calipers to make sure there is not any problem with the calipers and will be installing them the rest of the day. Hope this fixes the problem.
Old Aug 3, 2011 | 12:54 PM
  #36
knockbill's Avatar
knockbill
while you have them apart,, its a good time to flush out teh lines...
Old Aug 4, 2011 | 04:05 PM
  #37
BillyTz06's Avatar
BillyTz06
I installed the 4 new calipers yesterday and tried bleeding the brakes this morning. I have the same freekin' problem. Pedal to the floor and it will not pump up even enough to bleed the calipers no matter how many times I go around the car from wheel to wheel. I took the master cylinder off and bench bled it again. Put it back on the car and same thing.This just makes no since at all. I called several repir shops and they can't understand it either. I was going to start loosening the brake line connection to try to find the stopage but with no pedal I can't apply pressure. I think I will order a motive from Summit and see if that will pressureize the lines.The brake light on the dash is not lit and I get hardly any fluid from any caliper. Any more ideas. The porportioning valve is the ony thing I have not replaced. NAPA said they didn't carry them.
To Quick master cylinder question
Old Aug 4, 2011 | 04:56 PM
  #38
noonie's Avatar
noonie
One more time....
Take the prop valve apart and clean it.
Then test for pressure into the prop valve.
  #39
knockbill's Avatar
knockbill
somethings wrong here.... did you blow out the lines with air when you had teh calipers off? as you said, you can't use the mc if its not pumping up,,, if you are working on a 68, its just a switch to operate teh dash light, not a proportioning valve,,, i took mine apart, thinking the same thing,,, i would blow air thru all the lines from the mc line back, and make sure they aren't stopped up,,, if they are clear, i'd try a known good mc, like teh old one, if it worked,,,
do you new calipers have one bleed valve or two?,,, if two, you have to bleed them both, as far as i know....
Old Aug 4, 2011 | 05:33 PM
  #40
BillyTz06's Avatar
BillyTz06
Does the prop valve come apart or do you mean remove the brake lines from the valve and clean it out? If it was the prop valve wouldn't I be getting pressure to the front and not the rear or pressure to the rear and not the front, depending on which way the valve was stuck. I can try that in the morning though. I didn't blow the lines out because I was getting plenty of fluid flow through the lines before I started replacing parts, If the lines were stoped up wouldn't I have some pedal pressure? Remember I did crack the lines at the master and bleed some fluid out each time I reinstalled the master so I don;t think there would be much air left in the lines before getting to the calipers. I just found out that Advance Auto Parts has a pump up power bleeder as one of their loaner tools. I will borrow that in the morning rather than ordering a motive. If anything was stopped up or valves closed ,etc., in other words anything preventing flow, why wouldn't I have some pedal pressure . It would be the same as putting plugs in the m/c ports to stop the flow and I had a rock hard full pedal when I did that. There is just more to this than I understand.
