what gear do i have
Old Jul 30, 2011 | 01:56 PM
73 Rat Power's Avatar
73 Rat Power
Default what gear do i have
At 80 mph I'm running 3000 rpm. Any thoughts?
Old Jul 30, 2011 | 02:04 PM
wombvette's Avatar
wombvette
pretty damn tall.
Old Jul 30, 2011 | 02:07 PM
bluthundr's Avatar
bluthundr
Best way is to look for the stamp on the rear end. a 3.36 was standard for 73, might also be a 3.08 based on those numbers.
Old Jul 30, 2011 | 02:14 PM
73 Rat Power
It's a 454 4 speed numbers matching.
Old Jul 30, 2011 | 02:25 PM
...Roger...'s Avatar
...Roger...
Seems I remember some have said 79s with the 373 would run 3500 at 70.
Old Jul 30, 2011 | 03:23 PM
scottyp99's Avatar
scottyp99
Are you asking us to tell you what rearend gear ratio your car has?
Scott
Old Jul 30, 2011 | 04:38 PM
Mike Ward's Avatar
Mike Ward
Any thoughts? I think you're probably going to get a ticket.
Old Jul 30, 2011 | 04:44 PM
'75's Avatar
'75
225/70/15 tires, 3023 rpm @ 80mph = 3.08 gear
235/70/15 tires, 2963 rpm @ 80 mph = 3.08 gear
Old Jul 30, 2011 | 06:29 PM
7T1vette's Avatar
7T1vette
3.08 .... My 3.36 turns 3000 rpm at 70 mph.
Old Jul 30, 2011 | 06:52 PM
73 Rat Power
Scott
Most of you folks are great, but there are a few pin heads, grammer queens, and how dare you ask that question types! I just bought the car Skippy! So lighten up and add some assistance!
Old Jul 30, 2011 | 07:22 PM
scottyp99's Avatar
scottyp99
LOL!!! "grammer" queens! I can dig the irony, man, and I can see that you have a sense of humor, but I'm not really sure what you're getting all upset about, I was just trying to clarify what it was you actually wanted to know. What are we supposed to do, just start throwing random information at you until we stumble onto what it is you actually want to know?
Anyway, here's how to figure out what your rearend ratio is: Put the back of the car on jackstands, make a chalk mark or a mark of some kind on one of the rear tires, and the driveshaft. Spin the tire one full revolution, while counting how many times the driveshaft turns. Just a hair over 3 turns? 3.08. Just about 3 and 3/4 turns? That's a 3.73. Get it? It's better than trying to figure out rearend ratio from rpm at speed, because there are variables like tire diameter, and how accurate the speedo is, stuff like that.
Scott
Old Jul 30, 2011 | 07:45 PM
73 Rat Power
Scott
That's what I'm talking about Scott, thanks for the info. The speedo is dead on and I'm running 235/60/15's all around "Road Huggers". 3-grand at 80 mph.
Old Jul 30, 2011 | 08:05 PM
rcread's Avatar
rcread
Given these facts, you have the rare 2.91 ratio.
Old Jul 30, 2011 | 08:59 PM
Mike Ward's Avatar
Mike Ward
Tire size is irrelevant when figuring out rear end ratio vs. speedo indication.
Old Jul 30, 2011 | 09:33 PM
bluthundr's Avatar
bluthundr
That's correct. Assuming no one has changed the speedo gear out, you just have to know what tire size came with the car. A GR70x15 is around a 215/70/15.
Old Jul 30, 2011 | 10:03 PM
7T1vette's Avatar
7T1vette
G70 is equivalent to a 225 wide modern tire. (F70 = 215)
Old Jul 30, 2011 | 10:05 PM
scottyp99's Avatar
scottyp99
Well, there ya go, according to your "dead on" speedometer, you have the ultra-rare 2.91 rearend ratio. Maybe your tach is not 100% accurate. Maybe your speedo is inaccurate. Maybe your clutch is slipping just a teeny-weeny bit. Maybe there is a loose nut behind the steering wheel. The only way to REALLY know, is to take the cover off and count the teeth. That's a pretty big job on a 'vette, so counting the driveshaft revolutions is the next best thing.
Scott
To what gear do i have
Old Jul 30, 2011 | 10:39 PM
Mike Ward's Avatar
Mike Ward
Scott
No, the problem is putting the tire diameter into the mix.
Old Jul 30, 2011 | 11:49 PM
rcread's Avatar
rcread
Yeah, the speedo assumes you have oem tire diameter.
Old Jul 31, 2011 | 02:04 AM
Ironcross's Avatar
Ironcross
In 1973 we were well into emission controls .....and dealer inventory ordered cars would be the standard ratios as performance was already history....With 'OEM size tires a tach reading of 3000 RPM reads 60 MPH on the odometer and would be a 4.1 gear....which was not available in 73
