Heater core shutoff causing overheating
Old Aug 1, 2011 | 09:32 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
I'm with Mike W on this one, unless you have the heater on in the cab its not providing any additional cooling so its just circulating water from the intake to the inlet of the pump.
Could it be possible that the flow through the radiator or T-Stat is marginal and the lower hose is collapsing when the flow from the heater core is stopped. Could the extra flow form the heater core be just enough that it prevents the hose from collapsing.
Just throwing ideas out there
Neal
Old Aug 1, 2011 | 10:26 AM
wcsinx's Avatar
wcsinx
Be sure you have a bypass hole through your thermostat. If you don't, then stopping heater core flow can stagnate the water in the intake. Thus no coolant moving past the thermo, and it never opens.
Old Aug 1, 2011 | 10:29 AM
Mike Ward's Avatar
Mike Ward
Big blocks have a bypass hose from the pump to the manifold. Small blocks have a bypass in the legs of the pump.
The hole in the 'stat theory has, well, holes in it.
Old Aug 1, 2011 | 11:33 AM
wcsinx's Avatar
wcsinx
Not all of them
No doubt, but his symptoms seem to point to a thermostat that isn't opening.
Old Aug 1, 2011 | 11:39 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by wcsinx
Not all of them
You're right. Earlier SBCs have an external bypass like a BBC.
Old Aug 1, 2011 | 11:52 AM
...Roger...'s Avatar
...Roger...
Originally Posted by vette427-sbc
I just installed a heater core shutoff valve in my car and like the title says, my car now overheats. I didnt read anyone else saying they had this problem in the big shutoff valve thread. Is it just me?
The valve is a 3/4" pex ball valve (fits perfect BTW) installed in the 5/8 fluid feed line to the heater core. My car used to stay at 180-195* no matter what kind of driving. Now it spikes to 220+* with normal around town driving. If I open the valve to let the antifreeze flow, it drops right back down to 180*
I saw the bypass valve that connects the two lines via a vacuum source, but I do not have any vacuum lines to connect it to anymore. Ideas?
If you have the plug in the top of the water pump you might try unscrewing it until antifreeze starts to come out,sometimes a pocket of air gets caught there.
Old Aug 1, 2011 | 11:54 AM
tortisevette's Avatar
tortisevette
Are you blocking the heater core or bypassing it? I suspect you are just blocking it.
May have to buy another valve and install a bypass hose with valve ahead of the blocking valve.
Old Aug 1, 2011 | 05:33 PM
baja216's Avatar
baja216
I had the same thing happen to me with my '80. I had a high flow water pump installed, with the correct high flow thermostat (three holes drilled). I totally got rid of the heater core hoses and put plugs in the manifold and water pump. The car would not stay cool at all.
I couldn't explain it, I'm not sure what it was but I had to put a hose between the water pump and the intake manifold in order for it to cool properly.
It was stewart warner stage two pump and a set of double hump heads, nothing fancy!
Old Aug 1, 2011 | 05:51 PM
vette427-sbc's Avatar
vette427-sbc
Im going to just go ahead and say that this problem has nothing to do with the condition of my cooling system. All of the components work perfectly, and will keep my car between 180* and 195*. No matter what- with the valve open. As soon as I close it, thats when the problem arises. If there was an air pocket in the system it would be overheating all the time.
The temperature gauge works properly and is accurate.
Yeah, just blocking it. Ill have to look into something like this... except I dont have vacuum going to my heater controls anymore.
http://www.ls1tech.com/forums/conver...ter-valve.html
Old Aug 1, 2011 | 06:12 PM
scottyp99's Avatar
scottyp99
Neal
I'm certainly no expert, and if I am dead wrong, please, somebody straighten me out on this, but it seems to me, that if the coolant flowing thru the heater core isn't really being cooled without any airflow thru it, and you block off the coolant flowing thru it, then all of the coolant running thru the engine will be sent thru the radiator, instead of a certain amount being sent thru the heater core, and not being cooled. Shouldn't this make the coolant temp even lower, if anything? But for the OP the exact opposite is happening. Fire it up and close the valve and watch the lower radiator hose, see if it is caving in. It's worth a try.
Scott
Old Aug 1, 2011 | 06:28 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
Originally Posted by Mashman
He means it isnt cooling at top effientcy.
I would first make sure any air pockets are removed. It may not have been clear with the prior post. But to remove any air pockets, with the cutoff(s) open, jack up the front end so the radiator top is the highest point on the car. Then run the radiator without a cap until it gets to operating temperature. This should remI've any air pockets. You an also drill a few 1/8th holes in the thermostat to help.
What do you do when your radiator has no cap and the system gets filled through the overflow tank?
Old Aug 1, 2011 | 07:27 PM
noonie's Avatar
noonie
Just try looping ther heater hose from the manifold to the water pump (bypassing the heater) and see what happens.
Old Aug 1, 2011 | 08:48 PM
  #33
bluthundr's Avatar
bluthundr
I removed my heater hoses and completely blocked off the intake and pump ports with pipe plugs - temp didn't budge. Your situation doesn't make sense.
Old Aug 1, 2011 | 10:16 PM
  #34
LancePearson's Avatar
LancePearson
Every time you cut a coolant line like putting in the valve it's possible to lose some fluid. When your engine is cool, open the radiator cap and see how much fluid is actually in the radiator cool. If it isn't up nearly at the top then you've been running with insufficient fluid in the radiator system. Might be from the line cut but might also be from some other thing. All I know is without a full fluid in the radiator they run hot as heck and i was surprised once when mine had less liquid than I thought after what I thought was a minor leak. Wasn't so minor after all.
Cold engine, check the radiator level below the cap.
I have the same valve inline and it had absolutely no effect on the engine temps when blocking water to the heater core.
Lance
Old Aug 1, 2011 | 10:21 PM
  #35
LancePearson
Default fluid level
When I had a leak I first filled the overflow reservoir and let it suck into the radiator overnight. I thought that was enough. It wasn't. Took cooling and checking fluid in the radiator itself then filling.
If you lose enough refilling from the reservoir is inadequate.
I don't know if you've checked but you may be losing fluid at high pressure enough that you don't have enough. Double check how tight the new valve hose clamps are so it isn't a small leak from there.
Something's going on assuming the water pump and radiator are working right.
Lance P.
Old Aug 1, 2011 | 10:48 PM
  #36
doctorgene's Avatar
doctorgene
Yes Sir; I have a complete new system, motor, heater core, radiator, hoses & both fans, engine & Auxiliary, Yes when I first take the car out on a cruise, at 35 MPH, the temp. will rise, with the heater shut off, by the pex valve, to around 230, at which time my auxiliary fan will kick in, & cool it right down to approx. 205. With the heater pex valve open, it will not get above the 190 which the thermostat is set at. But the first lesson you learn, is that if the water is not boiling out of the system, the system is not overheating. The auxiliary fan is set to come on at 230 at the factory. You are worrying too much in my opinion. If you don't, like less heat in the cabin, leave the pex valve open, so you won't have to worry. Have a great day, Gene
Old Aug 2, 2011 | 08:09 AM
  #37
pawpaws toy's Avatar
pawpaws toy
I installed the same valve you did a week ago and had an overheating problem also. Ended up had a little air in the system and just needed to burp. Now runs 180. Did you install the valve in the heater hose from the intake manifold?
To Heater core shutoff causing overheating
Old Aug 2, 2011 | 07:57 PM
  #38
randyredleg's Avatar
randyredleg
Since many of these cars came with the shutoff valve from the factory, then the concept must be ok.Agree that it is very likely air in the system or a loose hose connection or that the radiator cap is not screwed on tight.
Old Sep 3, 2011 | 12:26 PM
  #39
...Roger...
How did this turn out ?
Did you check your pump to make sure the bypass was not blocked by the engine builder ?
Old Sep 3, 2011 | 02:53 PM
  #40
couperdecar's Avatar
couperdecar
I had this EXACT problem with my 350 sbc with vortec heads. Got myself a 383 and put the vortec heads back on AND bolted a DeWitts rad on.... SAME PROBLEM. Thought I was going crazy. Changed the thermostat out 3 - 4 times (can't remember now) Always the same thing.
Posted here awhile back and everyone here said , its the rad , its an air pocket , its the thermostat. Then someone posted they were having the same problem with VORTEC heads. And someone else posted that vortec heads don't have an internal bypass , that if you put in a manual shutoff valve you will damage your water pump . I'm not sure but maybe your after market heads are like the vortecs. I don't know. But I do know that I still run the 2 manual shut off valves (have them turned off now) but I had to add a bypass valve ahead of the whole works - and everything runs at 180 deg. If I shut the bypass valve it spikes to 260 then down to 180 then to 260 ........
