Coasting in drive ?
Old Aug 5, 2011 | 05:53 PM
boltnut's Avatar
boltnut
Default Coasting in drive ?
When my 350 with an auto trans is in drive shouldn't I be propelled forward just a little when the gas is not applied and the braked is not depressed ? Curb idle is 650rpms in gear....
Old Aug 6, 2011 | 12:48 AM
7T1vette's Avatar
7T1vette
Depends on whether you have a stock torque converter on it or one with elevated stall speed. Also, it depends on the tires you have and how much pressure is in them. On flat pavement, a stock car with stock converter and set up per GM specs, yes, it should move forward on its own.
With a 2000 rpm stall speed converter (or higher), wide tires with low pressure, it probably won't move at all.
