Dash crack - help
Old Aug 5, 2011 | 09:16 PM
Go MAD's Avatar
Go MAD
7th Gear
Default Dash crack - help
Does anyone have an idea or suggestion on how to slow or stop a crack in my dash from spreading. I have a 1981 vette and a small crack has started on my dash.
Thanks in advance for any help
Old Aug 5, 2011 | 10:46 PM
C3Dave's Avatar
C3Dave
I fixed a small crack in the dash of my 79 using body filler. Use the search feature in the C3 general forum and you will find lots of ideas.
Old Aug 5, 2011 | 11:10 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I've never repaired one with body filler, I'll have to try this.
We do have the new pads on sale right now though... you get an additional 10 percent off the forum price until the end of the month.
http://willcoxcorvette.com/advanced_...rds=dash%20pad
Old Aug 6, 2011 | 08:41 AM
Go MAD's Avatar
Go MAD
7th Gear
Thx C3Dave
Old Aug 6, 2011 | 10:34 AM
AT-82Collectors's Avatar
AT-82Collectors
My dash had a crack in it and also a chunk about the size of a pencil eraser missing. I took the car to my body shop on the day that the person who repairs seat upholstery and the such was there. He repaired both and did a excellent job, matched the color on a ’82 dash. You can’t see where the damage was. Cost something like $55 I think. You may want to check with your used car dealer or a body shop to find one of these guys.
Andy
Old Aug 7, 2011 | 09:19 AM
Go MAD's Avatar
Go MAD
7th Gear
Thanks Andy
Old Aug 7, 2011 | 12:12 PM
Indiancreek's Avatar
Indiancreek
I'm suspect if it started cracking in one spor additional spots will begin to show up. The entire dash is the same age. I'd vote for the replacement while they are on sale. I'm thinking about it for mine. I fixed a Camaro once and again and again and again. Then broke down and replaced it. Looks better and I don't keep seeing new ones. They don't give them away, but it's the part you see everytime you're in the car and all the time driving it. All your passengers see it while they are riding with you.
Kind of like putting new carpet in and painting your house before you try to sell it. When they look good they seem to drive better.
Old Aug 7, 2011 | 12:21 PM
7T1vette's Avatar
7T1vette
You can fill the crack with polyester body filler (spot putty), but that won't stop a propagating crack. You first would need to put some kind of sturdy fabric or thin plastic patch under the end of that crack (use good epoxy to bond it to the vinyl top skin) so that the crack will not continue. Then use the body filler to get the cracked area up to the same level as the top skin...this may need several 'fills', as the filler shrinks when it dries. Finally, use SEM ColorCoat vinyl dye to recolor that area to match--or just re-dye the whole dash top so that the patch doesn't show.
Old Aug 7, 2011 | 11:51 PM
mrmagrath's Avatar
mrmagrath
I came across a product called Padded Dash Filler, or something. Supposed to be designed for the job. I don't think it's available here in New Zealand.
I haven't had much luck using bondo to fill cracks in the dash pads and windscreen trim. Even tried using plastic bumper filler. Must be doing something wrong. Either that or the bits are too dried out and brittle.
To Dash crack - help
