Boyd Wheels question
Old Aug 6, 2011 | 11:39 AM
skeeter5070's Avatar
skeeter5070
El Camino
Default Boyd Wheels question
Hello, I have a 74 and am looking at purchasing 16" Boyds with 1/2 offset and 5 " back spacing. Will these wheels fit my 74.
Thanks...
Old Aug 6, 2011 | 12:30 PM
3JsVette's Avatar
3JsVette
Not correctly. Too much backspace. On a 8" wide wheel the perfered backspace is 4". It sounds like this is a set of wheels that someone has for sale. Is that the case? If so pass. 1st of all if you're looking to upgrade you have many more tire choises in 17s. If you are on a strict budget and this is a performance upgrade you are better off with some late model take off wheels/tires and adapters. Remember no matter how good the deal is it's NO good if what you buy doesn't fit.
Old Aug 6, 2011 | 12:47 PM
skeeter5070
El Camino
Thanks, and you are right.
I kind of knew it myself but was just trying to force it..
I hear 4.5 back space and 0 offset most of the time.
Old Aug 6, 2011 | 01:09 PM
zwede's Avatar
zwede
On an 8" wide rim I prefer 4" BS:
Old Aug 6, 2011 | 06:30 PM
skeeter5070
El Camino
4" looks great, I don't know why it seems like I am always hearing 4.5" backspace needed.
Old Aug 6, 2011 | 07:11 PM
3JsVette's Avatar
3JsVette
No not really. The 5 spoke Boss wheels have become popular of late and I believe they are 4.5" backspace which will work. If you do a search using "17s" you will find most are using 4" backspace with a 8" wheel. Case in point look how good "zwede's" car looks.
Old Aug 10, 2011 | 12:10 AM
skeeter5070
El Camino
Great 4" BS it is... !
0 offset
Old Aug 10, 2011 | 08:21 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
When I ordered my Boyds years ago I got them in 8 inch wide with a 4 inch BS. I would guess someone got those wheels for another car.
Old Aug 10, 2011 | 08:48 AM
lvrpool32's Avatar
lvrpool32
You usually see 8" wheels with 0 offset or 4.5" backspace because that puts the mounting face of the wheel in the center of the wheel.
Nick
Old Aug 10, 2011 | 09:51 AM
qwank's Avatar
qwank
4.5" backspace works for pretty much every other GM vehicle, that's why you see them more often. The Corvettes have a wider body they require the extra 0.5" otherwise they are tucked in too far.
Old Aug 10, 2011 | 11:08 PM
3JsVette's Avatar
3JsVette
0 offset
NOT 0 OFFSET!
A 8" wheel is not 8" wide (what? I know) it is 9" wide. The width is measured from tire bead to tire bead which is the inside of the wheel not the outside edges. So in reality the wheel has a 1/2" offset.
To Boyd Wheels question
