17" tire question
Old Apr 28, 2002 | 12:49 PM
70 LS1's Avatar
70 LS1
Default 17" tire question
What size tires are you running with 17" wheels?
Old Apr 28, 2002 | 03:04 PM
terryrudy's Avatar
terryrudy
Default Re: 17" tire question (70 LS1)
I got 255/50s on mine.
71roadster has 255/45s on his which are a little smaller. His sidewalls are perfectly flat, mine bulge just a little.
-terry
[Modified by terryrudy, 11:04 AM 4/28/2002]
Old Apr 28, 2002 | 03:23 PM
zwede's Avatar
zwede
255/50-17 are the same diameter as stock tires, so your speedo will be correct and the wheel well will be filled.
255/45 or 245/45 will be about 1" smaller in diameter. The wheel well will look empty unless you lower the car.
Old Apr 28, 2002 | 04:09 PM
70 LS1's Avatar
70 LS1
Default Re: 17" tire question (zwede)
How wide are your wheels?
Old Apr 28, 2002 | 07:23 PM
jdunne's Avatar
jdunne
255.50.17 on 8"rims........as markus said,that is the same overall height and no clearance issues at all........john :chevy :cheers:
Old Apr 28, 2002 | 07:39 PM
zwede's Avatar
zwede
8". They're wheel vintiques 17" ralleys. I love them except the weight. Someday I'll get the WV billet ralleys.
Old Apr 28, 2002 | 08:41 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
255/45/17 on 8" wheels :) .
Old Apr 28, 2002 | 10:54 PM
mrvette's Avatar
mrvette
Default Re: 17" tire question (jdunne)
255/50/17 on 9.5 inch rims in front,...'92 vette wheels with adaptor...
275/50/17 in same rims in rear....moved Ebrake bracket to behind rotor where it belong to start with....
GENE
Old Apr 28, 2002 | 11:20 PM
Double Aught's Avatar
Double Aught
Firehawk SZ50 P255/45ZR17 front }17x9.5
" " P285/40ZR17 rear }17x9.5
Front end is lowered via F41 coils from VB. Dropped it at least 1.5 or more inches. :cool:
[Modified by sd pacecar, 7:22 PM 4/28/2002]
Old Apr 29, 2002 | 12:04 AM
79er's Avatar
79er
Default Re: 17" tire question (sd pacecar)
255/50/17 on 17x8 rims
To 17" tire question
