Gas Pedal linkage !!!!!
It just felt as if power just wasn't there. I thought that something on my tuning was off; maybe my timing was off or my jetting was off or my fuel flow was restricted or I had a vac leak or my MSD was losing power or maybe I had a grounding issue or something.
All I knew was that I was now suddenly running like a 12.017, 12.010 @ 114mph and such with still the same 1.50's 60' times. I used to run consistent 11.8's or the occasional 11.7s @ 125mph with 1.50's.
I couldn't figure it out for the life of me what was causing my slow down, until I came across this post:
http://forums.corvetteforum.com/c3-t...kage-pics.html
Turns out after a bit of testing, my throttle only opened to about 80%. Okay, I thought, lets tighten up the cable a little bit. Still no full throttle, I got at best 85% throttle now.
I go inside and remove my pedal to find that the top of it where the "O" is was bent back. Additionally the whole linkage was slightly bent. I bent it back to factory and I will now get about 95% throttle.
Still not 100%. The stock assembly is a little bit weak and soft and I'm sure that over the years the metal has become soft.
So I ordered a Lokar Pedal from Summit - http://www.summitracing.com/parts/LOK-BAG6004/?rtype=10 along with a new stainless throttle cable and all my problems are solved. I easily have 100% throttle now, my pedal does not feel mushy anymore and it actually feels better than stock.
I just posted all this because I think some C3 owners may have the same issue as me and I just wanted to share what I found out. Go under your hood and have your wife/gf/girl toy push all the way down on the gas pedal and check to see if you really are getting full throttle!
