TH400 Help!! High RPM problem
The problem is that I have 3700 RPM at 50 Mph. ( With sidepipes this makes a lot of noise)
The transmission gears from 1 to 2 of 20 Mph and from 2 to 3 at 33 Mph.
When I gear from 2 to 3 the RPM drops with 700 RPM.
The transmission was originally from a Chevy diesel truck / van.
The TH 400 should have a 1-1 ratio at 3rd gear.
My rear wheels are 64 cm in diameter.
If everything was working as it should I should have 2100 RPM at 50 Mph.
Could someone give me some tips?
