Best Overall Engine?
Old Aug 19, 2011 | 10:22 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Originally Posted by Factor
So, here is the question........What engine size/displacement provides the best overall (street/driving/roadcourse) performance?
427? 454? 489?
BTW, I do have a 454 BBC MK IV engine that can be built....
Thanks!
Ron
Unless you are class racing, the old adage still holds true. There is no replacement for displacement.
You can build a 496 BBC for about the same price as a 427 or 454.
With aluminum heads and intake, they dont weigh much more than a cast iron small block.
Old Aug 19, 2011 | 10:50 AM
babbah's Avatar
babbah
Originally Posted by scottyp99
there is still something about a BBC.......
Scott
There is no substitute!
Old Aug 19, 2011 | 11:03 AM
7t9l82's Avatar
7t9l82
a big block with the right bottom end will be cheaper and make more power and last longer. strokers are nice but the rod angle isn't as good and bore wear is normally higher which will reduce ring seal faster. early pro stock motors used mostly stock bottom ends and held up well and approached 850-1000 HP no smallblock with a stock bottom end ever did that.
Old Aug 19, 2011 | 03:02 PM
69vettester's Avatar
69vettester
You just go ahead and balance the front and rear suspension to work well with the extra weight.
It wasnt great but Thats what GM did. It helps for the frame to be spot on
Old Aug 19, 2011 | 05:31 PM
Tim H's Avatar
Tim H
Im not a big block fan at all.
I would take a nice 400 horse 350 any day and be very happy!
Old Aug 19, 2011 | 06:31 PM
Factor's Avatar
Factor
THANKS! for the feedback!
I guess I want the speed and power...but also dont want to own a fuel station. I do have a 454 block here, but will need to build it-so that is cost...
how much suspension work is needed for a BBC? (will prob go alum heads too)
there is definitely something sexy to say about a "big block vette"
why build a 427 when I could do 454, or 489...?
also, what does an LSX engine go for? plus where are we at with additional costs?
I guess I am struggling with trying to find the proper power for such a light car......because too much means nothing but spin....and too little....etc...
Thanks,
Ron
Old Aug 19, 2011 | 06:50 PM
gkull's Avatar
gkull
I vote for LSX just because it comes dry sump and they can be made out to 472 ci. Add a supercharger for even more fun.
To actually make a road racing car you need a bigger rear weight bias. My Vette is getting near 60% rear and 40% on the front. A local vintage racing 496 ci GT1 Vette can't keep up with my little 434 small block. He 300 pounds more and he is way nose heavy. We used to go together and even use the same tires and wheels. . His dynoed at 700 something HP and I might have something over 600. He had 60 more ci and I would still blow by him on the main straight.
Old Aug 19, 2011 | 07:02 PM
billla's Avatar
billla
St. Jude Donor '14
I'd note in passing that Zora was kind of horrified by the BBC in the C3 for a number of reasons but mostly a disruption of his weight distribution. The C3 is a beast with a BBC (I've owned a couple), but IMHO it's far more agile and fun with a hot SBC...
To get an answer to your question , you really - really - need to say what your budget is. Honestly, it's the only way to decide some of these options...
scottyp99's Avatar
scottyp99
I have never done either, so I can't speak from experience here, but I think you'll have to throw a good chunk of money at it to do an LS conversion properly, and a BBC conversion, although you will have to spend some money, will not hurt quite as bad. The fact that you already have a BBC is a big factor in why I say this. Another thing that I will say, based on absolutely zero experience, is that I don't know if I would bother to do an LS conversion unless I could score an aluminum block engine, which still command a nice chunk of change. The LS motors came out in '97, and were pretty popular by '04 or so, so it shouldn't be too long before the boneyards are literally flooded with them.
Scott
Old Aug 19, 2011 | 09:44 PM
billla's Avatar
billla
St. Jude Donor '14
Already happened, especially with the iron blocks but the aluminum ones aren't particularly difficult to find or horrifically expensive.
Pioneering for conversions is pretty much over - the parts and kits (motor mounts, swap headers, etc.) are all now pretty much readily available and fairly reasonably priced. It's typically the other stuff that adds up - fuel pump and lines, driveshaft, etc.
Old Aug 19, 2011 | 10:05 PM
69ttop502's Avatar
69ttop502
Originally Posted by joewill
got any pics?.. I would love to see a 348 or a 409 in a vette!
Me too? I would think you could get some decent money for that 348. Kinda cool. How does she run?
Bill
Old Aug 19, 2011 | 10:50 PM
scottyp99's Avatar
scottyp99
Well, there you go, from someone who sounds like they know what they are talking about, unlike me!
I still think there is just..........something...........about a big 'ol' big block!!!!! I have had cars with big blocks, and man, it's cool!!!
Scott
Old Aug 19, 2011 | 11:08 PM
  #33
billla's Avatar
billla
St. Jude Donor '14
Don't get me wrong, I completely agree! I had an El Camino with a 454 and it was awesome! But...
I've done a couple of LS swaps now and they're not...easy, but they're pretty straight forward not the fab-fest that they were a few years ago. I helped with one early on and it was way beyond my skills. The last one was pretty much plug-and-play with the exception of needing to do a very small amount of frame clearance. It was an iron 5.3, including the trans and it really just pretty much dropped into a '70 C10.
Old Aug 19, 2011 | 11:31 PM
  #34
scottyp99's Avatar
scottyp99
There is one thing I will stick to my guns on, I wouldn't bother doing an LS swap in a 'vette unless it was an aluminum block. It would just always nag at me if I had a cast iron LS, ya know what I mean?
Scott
Old Aug 20, 2011 | 12:30 AM
  #35
63mako's Avatar
63mako
St. Jude Donor '08-'09
My Ideal engine starts with this.
http://www.summitracing.com/parts/DRT-31264444/
Then this.
http://www.cnc-motorsports.com/produ...83&CtgID=28761
Then these.
http://www.cnc-motorsports.com/produ...D=28707&CtgID=
and one of these.
http://www.summitracing.com/parts/CCA-11-704-9/
That will get you started. It will bolt right in. Might need a new hood for the intake to match this though. Lighter than a small block.
Old Aug 20, 2011 | 08:27 PM
  #36
Factor's Avatar
Factor
63Mako....I like your style!!! I was thinking 489....buddy has one in his chevelle and it is wicked!
Bill....thanks the 348 runs great. no issues. very reliable...just stock power so 260HP and prob 320TQ or so....why you interested? she will need a new home....
SO the burning question:
1) cost of LSx swap? general....ie, electrical, etc. how does it break down...
2) what mods will be needed for the BBC? (since the 348 is in there now)
3) what is possible weight difference between LSx and iron BBC with alum heads?
Shoot me your thoughts...
Thanks,
Ron
Old Aug 20, 2011 | 08:34 PM
  #37
billla's Avatar
billla
St. Jude Donor '14
Might be fun to do a Grand Sport kinda thing...377 CID, all aluminum...turn it to 8 grand.
*chuckle* sorta the anti-BBC
To Best Overall Engine?
Old Aug 20, 2011 | 09:07 PM
  #38
Vette5.5's Avatar
Vette5.5
Since you're throwing fuel milage into mix, that would be aluminum LS engines. My current Vette's, actually a C6 ZO6. While a lot of it's the 6 speed Tremec gearing, even at 7.0 litres(427 cu in), no problem getting 25-26 mpg highway at 70 mpg all day long. The smaller LS's, do even better.
Old Aug 20, 2011 | 09:11 PM
  #39
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The best engine for a C3 is what I have . Don't get me wrong, I dreamed about building this motor for years and finally had enough coin to do it and I went ahead and spent quite a bit of money. But I am very satisfied with the outcome.
I first wanted a an LS motor and my friend took me over to a pile of blown up LS motors that guys had been putting power adders on and they blew up, he steered me towards what I have now, a 600+HP small block, with a bullet proof 5 cap 4 bolt billet splayed cap block with the appropriate parts to go with it and top end to match like T&D shaft rockers, AFR 227 heads blah blah blah. I'll never have the coin to build anything like it again.
Now talking about big blocks, sure they are the cats azz but I opened the hood on my buddies 427 '69 big block and I just could not believe how cramped up it was in there. No room for anything, I like the motor but I like some room to work too.
The best bang for the buck for our C3's because mine was so f'ing expensive would be a Dart SHP block and 3.75" crank with some nice ~ 285-300cfm heads and you have yourslelf a 550HP monster in smaller form and it bolts right in
Old Aug 20, 2011 | 09:32 PM
  #40
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Much like my own build
** Lots of LS stuff already on CF, the search engine will get you plenty of reading
