Best Overall Engine?
Old Aug 21, 2011 | 05:50 PM
  #41
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by Factor
63Mako....I like your style!!! I was thinking 489....buddy has one in his chevelle and it is wicked!
That block I linked is aluminum. 160# Block. 4.50 bore, 4.25 stroke. (same stroke as 489) Combo is 540 CI, over 700 HP Pump gas, plenty of bottom end, 7000 RPM redline and total weight is about the same as an aluminum head small block. It will bolt right in but will run about $13,000 to build. Better have some left in the wallet for powertrain upgades as you start breaking things.
Old Aug 24, 2011 | 02:58 PM
  #42
Factor's Avatar
Factor
Thanks Guys!
R
