Best Overall Engine?
Old Aug 18, 2011 | 12:06 PM
Factor's Avatar
Factor
Default Best Overall Engine?
Hi guys,
I have a replacement engine in my 69 convert. It is a 348 (yes, '59 348 W code...all complete), thus it is low HP, about 265HP.
I will be selling this engine when the weather breaks (if anyone interested), and will be looking for more power! I also drive it frequently. I want more power because I did have a 70 chevelle SS 396.
So, here is the question........What engine size/displacement provides the best overall (street/driving/roadcourse) performance?
427? 454? 489?
BTW, I do have a 454 BBC MK IV engine that can be built....
Thanks!
Ron
Old Aug 18, 2011 | 12:14 PM
Ganey's Avatar
Ganey
They all can work great. The 454 sounds very good for you.
Duntov did not put the 348/409 into the Vette because of the about 100 lb weigh penalty.
Old Aug 18, 2011 | 12:17 PM
69vettester's Avatar
69vettester
Originally Posted by Factor
Hi guys,
427? 454? 489?
Thanks!
Ron
348's were BB engines werent they? Did they evolve into the 396?
The stroked small block has become one of the premier engines for street. GM has made a factory 383 for many years now.
I would pick the BB 427 from your list to build a monter street engine, but they weigh so much, its harder to get superior results than for a stroked small block.
Old Aug 18, 2011 | 12:24 PM
Ganey's Avatar
Ganey
No they did not evolve into 396. The BBC a different engine & is 427+. The 396 was a debored 427, i.e. not bored all out because GM had a policy of no more than 400 c.i. for midsize- smaller cars.
Old Aug 18, 2011 | 12:35 PM
69vettester
But the 348 evolved to the 409 is that Right?
Old Aug 18, 2011 | 12:36 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you need to review and consider all the changes, moving into BB motor.
They add up quickly. 454 BB most bang for the buck, and the most reasonable parts cost.
Old Aug 18, 2011 | 12:39 PM
Gordonm's Avatar
Gordonm
I would never build a BB 427, even a BB 454 is small by todays standards. A SB can be built in the 427 variety now with ease. A 502 is the minumum BB I would build. If you are looking to have a crate motor or something like that and stay wit ha Bb then a 502 is a nice motor. What kind of power levels are you looking for.
Old Aug 18, 2011 | 12:40 PM
Ganey's Avatar
Ganey
Yes 348 & 409 are the same basic engine.
Old Aug 18, 2011 | 12:44 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Crate BB would be 502 or greater, SB I would go with an LSx because of the weight, performance, fuel economy due to you driving often....
Old Aug 18, 2011 | 12:57 PM
joewill's Avatar
joewill
got any pics?.. I would love to see a 348 or a 409 in a vette!
Old Aug 18, 2011 | 02:04 PM
cottoneg's Avatar
cottoneg
Hi guys,
427? 454? 489?
Thanks!
Ron
For a road course in my 1969, I wanted a small block. I went with a 383/450 hp stroker. More than enough horsepower for me and it runs on street gas.
Old Aug 18, 2011 | 02:22 PM
billla's Avatar
billla
St. Jude Donor '14
The question is a bit tough without a budget in mind
Starting from scratch I'd note that the best all-around performer would be an LS-series swap. Pretty tough to beat across the board in terms of power/$.
Don't get me wrong - I love me a wild GEN I SBC and BBCs - but the LS delivers big power, big torque, driveability, light weight and all at a pretty darn reasonable price.
Don't forget to factor in the cost of the swap components!
Old Aug 18, 2011 | 06:08 PM
Vette5.5's Avatar
Vette5.5
348's and 409's are the same block, and basically a truck motor from the 50's. You can easily identify these by the valve covers. Since you're asking for opinions, would at least go the largest cu in SB possible as 100 lbs less than a BB. Better still, an LS3, as 120 lbs less than an iron headed SB, and the L92 heads really flow.
Old Aug 18, 2011 | 07:00 PM
Ironcross's Avatar
Ironcross
Default The Best IS below
$1200.00`bought you a L88 that was factory built with all the right stuff........600 horsepower right out of the box....hard to beat with excellent components and a simple transplant into any Vette . The ZL1 is the same except the aluminum block......never again will they be available as they were back in the late 60`s......
it was actually a racing engine........
Old Aug 18, 2011 | 07:29 PM
scottyp99's Avatar
scottyp99
Well, if you have the money, the LS swap is the way to go. However, if you already have a 454 laying around, a BBC with aluminum heads, intake, water pump, and a set of headers, is going to be quite a bit more powerful, AND quite a bit lighter than what you have now. LS motors are cool as hell, because they are technologically advanced, but there is still something about a BBC.......
Scott
Old Aug 18, 2011 | 08:39 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'm chiming in because you mentioned roadcourse tracking could be in your future. A lot depends on your traction limitations and gearing as to how much and where you really need the power/torque located. For highly-spirited / RR type driving in the twisty bits you want to be able to get on the throttle good without necessarily having to be pointed in a straight line. In my case, a stout 427 fits the bill. Your results may vary.
Old Aug 18, 2011 | 09:31 PM
billla's Avatar
billla
St. Jude Donor '14
That there is
To Best Overall Engine?
Old Aug 18, 2011 | 10:33 PM
7t9l82's Avatar
7t9l82
a big block is what I'd build, but then again contact Lamar Walden and build a stroked 348 that is different and very cool.
Old Aug 19, 2011 | 09:56 AM
Doug 61's Avatar
Doug 61
Ohio Crankshaft sells a nice 454 small block.
Old Aug 19, 2011 | 10:08 AM
69 Chevy's Avatar
69 Chevy
The mouse motor, because of its lighter weight, will out handle a heavy rat motored C3. And with all the aluminum components available these days you can build a large cube mouse that actually weighs less than it's OEM counterpart from the 60/70's. Rat motors are better for drag racing.
