Torq Converter Question...
Old Aug 19, 2011 | 01:54 PM
Richard Cooper's Avatar
Richard Cooper
Default Torq Converter Question...
I have a new crate motor in my 81. I have also removed the computer and because of this I had to replace my distributor and carburetor.
The lock up torque converter was being controlled by the old computer. My question is: Will there be any damage done to the transmission because the lock up is not working? I am thinking that it will only hurt my millage, but not sure. Thanks in advance.
Old Aug 19, 2011 | 02:29 PM
bluedawg's Avatar
bluedawg
I beleave it will over heat the trans mission @ hyway speeds. Summit sells a kit made by painless that controls the lock up in 4th gear.
Old Aug 19, 2011 | 03:04 PM
7T1vette's Avatar
7T1vette
You will not damage the transmission if the lockup function is not operational. You will get a bit poorer fuel mileage for both highway and suburban driving (in-city will likely be the same). You can hook up your computer again and have it only operate the lockup clutch, if you want. Or, you can hook up a switch with 12vdc to send to the lockup clutch when you want to use it. However, I would not recommend that last option, as it doesn't take into account the ability to 'cancel' the lockup function when braking, when climbing a hill, etc. The ECM that was on the car will handle all of these circumstances, as long as you have it wired properly and have not removed the brake switch associated with the lockup operation.
Old Aug 19, 2011 | 03:38 PM
Richard Cooper
Thank you. I am going to leave it disconnected as long as it will not do any damage to the tranny. So, thank you once again and have a great weekend.
Old Aug 20, 2011 | 02:17 PM
45ACP's Avatar
45ACP
With a 350C, the three speed w/lockup used in '80 and '81, it is OK to not use the lockup. The only penalty is the loss of fuel efficiency.
With a 700R4, the 4 speed overdrive w/lockup used in '82, leaving the lockup function disabled will result in horrific overheating of the transmission.
Old Aug 21, 2011 | 02:20 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Why would it generate all that extra heat? A 700 lock up converter & a 350 lock up converter work the same way.
Old Aug 21, 2011 | 07:26 AM
45ACP's Avatar
45ACP
But the *transmissions* do not work the same way.
Disabling the converter lock-up function in a 350C was a trick to get around problems with the lock-up clutch in the converter. When the 700 came along, people that tried the same trick and were rewarded with a horribly overheated tranny. I mean so hot you couldn't put your hand on them. At that point a complete rebuild or replacement was the only option. Another converter was also needed.
Old Aug 21, 2011 | 08:40 AM
Ganey's Avatar
Ganey
When I was talking to Mike Kurtz (high performance trans. specialist) about a blown built (not by Kurtz) TH2004R he mentioned the TH2004R could handle a non lockup converter much easier than the 700R4.
Here's something not normally mentioned.
"Also note that the GM 700R4 (4L60) transmission does not route fluid to the cooler unless the TCC is locked."
http://www.diy-efi.org/gmecm/papers/tcc.txt
"it does but it is not alot"
Chris
christoforos Kokkonis,general motors transmission specialist
www.ckperformance.com
To Torq Converter Question...
