Corvette is not level
Old Aug 20, 2011 | 05:39 PM
ron drake's Avatar
ron drake
1st Gear
Default Corvette is not level
I'm working on a 1974 corvette. The whole right side is lower than the left. I've changed the shocks, springs, lower ball joints and as suggested checked the bushings and they were OK. I welcome any and all help with this problem. Ron
Old Aug 20, 2011 | 06:37 PM
7t9l82's Avatar
7t9l82
one thing to check is the front spring it needs to be seated properly the other would be the rear spring height adjustment.
Old Aug 20, 2011 | 06:39 PM
Alan 71's Avatar
Alan 71
Hi Ron,
Have you tried to get a look at the body mounts? Or is that what you meant by 'bushings'.
If they're extremely deteriorated that could allow the body to sag on one side.
How much is the difference and did you notice any problem before you began your refurbishment?
Regards,
Alan
Old Aug 21, 2011 | 08:47 AM
69 Chevy's Avatar
69 Chevy
Make sure the bolts that connect the trailing arms to the rear leaf spring are threaded evenly.
Old Aug 21, 2011 | 09:10 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Default check out this link.
Does this look like your problem ?
http://forums.corvetteforum.com/c3-t...-80-model.html
My problem was ultimately solved by replacing the body mounts. Drivers side mounts were flat from age, and had zero or 1 shim each mount. Pass side mounts were NOT flat and had 4 or 5 shims each. The assembly line people must have been drunk that day ???
To Corvette is not level
