slow lights?
Old Aug 22, 2011 | 07:24 AM
jman1's Avatar
jman1
Default slow lights?
my headlights go up one at a time... its very slow and delayed... maybe 5 seconds or more after i pull the switch... anyone?
Old Aug 22, 2011 | 09:04 AM
wombvette's Avatar
wombvette
Do a search, probably ten thousand hits. Find the leak, probably the actuator seals.
Old Aug 22, 2011 | 09:08 AM
78IndyPace's Avatar
78IndyPace
Could be one or more vacuum leaks. Could be crud in the relays causing the piston valves to move slowly. Could be a combination of things.
You're in for some troubleshooting. This might help:
How Your Headlight Vacuum System Works
Good luck!
Old Aug 22, 2011 | 10:52 AM
bigvette1's Avatar
bigvette1
Also get yourself some silicon spray and spray the mechanical movement points, may be just corresion also.
Old Aug 22, 2011 | 05:03 PM
Alan 71's Avatar
Alan 71
Hi jman,
Perhaps you should consider buying a vacuum pump, $, (like a mity-vac), which will enable you to test the relays, (if your year has 2), and actuators, using one of the trouble shooting guides.
This will allow you to know if you have parts that just need new seals, $, or if you need to buy new parts,$$.
Good Luck!
Regards,
Alan
Old Aug 22, 2011 | 05:38 PM
jman1's Avatar
jman1
that link was perfect.. im gonna tackle it this weekend...
Old Aug 23, 2011 | 09:58 AM
jcloving's Avatar
jcloving
Agreed. Get a vac pump. I got a mity-vac and a Harbor Freight vac pump.
I replaced the actuator seals, then rebuilt the relays. My hoses were ok.
Mine now pop up quickly although one of my relays still leaks a bit. Much better than when I got the car.
To slow lights?
