New engine time
I believe the engine was a GM - Fast burn, 385. http://www.gmperformanceparts.com/En...9710&engCat=sb
I had a fuel injection system and some other goodies that pumped up the HP to about 450. I can replace it with what I had but probably not re-use the injection system since it is pretty old at this point and there are a lot better systems on the market today.
I'm not even sure what kind of cash we're talkin' about to replace it.
Any ideas?
Any ideas?
$5,000.00-$6,500.00 will get you any of the Real nice stroker Crate motors available.
The zz-383 is Great, pricey.
More information on the trans and gears would help a bunch.
I'm not particularly fond of the 385. The Fast Burn heads are a bit Old Skool at this point; I'd lean towards the HT383 or ZZ383...although an LS is still the best choice if you can swing it
350 block, bored .040 over 383 crankshaft
Crane hydraulic roller cam: .509 intake/ .528 exhaust lift duration 284/292
Dart cast iron heads: Intake 2.05 exhaust 1.60
Roller rocker arms
Super-Ram Fuel Injection with adjustable fuel pressure and power tuner
Stock Distributor with adjustable vacuum advance
MSD spark control and coil
Hooker Side-mount headers
Transmission:
Richmond 5-Speed
Rear End: Rebuilt with 3.08 gears
I'm thinking I'm going to be in the $5K to $7K area or better, but I'd like to get some additional HP if I can, without replacing the whole back end.
I'm looking at my options with a new crate engine or a rebuilt, but I'm leaning towards the new because it comes complete with everything, plug and play (sort of).
I'm a bit confused as you noted you had a GMPP 385 crate...yet this description is of a completely different engine...?
Any ideas?
It wound up not being his fault. The engine was re-built incorrectly. But that is another story…OK.. I did some research on these boards and the local guys. I would up buying A 383/ 450 HP from Golin. I think the Corvette is plenty fast now. I have 335/35X17’s Michelin PS2’s on the rear and often brake them loose if I am not smooth.
They have a LT1 Long block 383/ 500 hp that runs on pump gas.
http://www.golenengineservice.com/en...t1-long-block/
Why anyone needs more than 500 hp that doesn’t race is beyond me. After than, stuff will start to break, which will lead to another whole set of projects.
Still, the route I'd take would be a new shortblock for sure. If the crank is good and the rods are aftermarket, you're just talking block, pistons/rings, bearings and machine work...pretty inexpensive overall.
I paid $1600 for mine, had it shipped and am VERY happy. Wouldn't hesitate again. Check out their web site.
Some people have all the luck....
