Noise on acceleration
Old Aug 23, 2011 | 08:43 PM
rsteenwyk's Avatar
rsteenwyk
Default Noise on acceleration
My 1980 Auto all of a sudden has started to make a noise while under power . it does not happen all the time but sounds like some one hitting one of the drive shafts with a wrench . It does change with the increase in speed . Can a bad u-joint be the cause ,and would it echo the sound through the drive shaft to enhance the noise .
Old Aug 23, 2011 | 10:44 PM
wombvette's Avatar
wombvette
Either the fan hitting the shroud or a bad snubber bushing on the rear end.
Old Aug 24, 2011 | 10:32 AM
brando1118's Avatar
brando1118
Detonation from bad gas?
Old Aug 24, 2011 | 04:15 PM
rsteenwyk's Avatar
rsteenwyk
The shroud shows no sign of fan contact . I believe the snubber bushing is on the metal bracket on the front of the diff (correct) there are chunks of rubber falling out of it . I will start with that . thanks so much for your help I am a corvette owner for a whole 3 weeks .
To Noise on acceleration
