Flywheel Question
Old Aug 30, 2011 | 10:34 PM
spedaleden's Avatar
spedaleden
Default Flywheel Question
How do you know if you need to replace the flywheel when changing clutch. What are the signs to look for.
Old Aug 30, 2011 | 11:04 PM
Korevette's Avatar
Korevette
Hot spots, indicated by a blue appearance, fine cracks, chewed up ring gear, general appearance for wear and the likes. I was able to buy a replacement clutch and they machined the flywall in the deal. $210.00 bucks later I got it covered.
Old Aug 31, 2011 | 02:08 AM
7T1vette's Avatar
7T1vette
If the surface where the clutch disc rides is not heat checked or gouged from excessive wear, it can likely be reused. If your clutch was slipping, that surface may be glazed; if so, you can use some medium grade sandpaper to rough it up a bit and clean off the surface so the new disc can 'grab' onto the steel surface.
Old Aug 31, 2011 | 07:45 AM
MN80Vette's Avatar
MN80Vette
If none of the starter teeth are missing, then just have the clutch surface machined. Most auto parts store will send it to an automotive machine shop. I had mine resurfaced a couple weeks ago for $35. That sure beats the cost of a new flywheel.
Old Aug 31, 2011 | 09:20 PM
spedaleden's Avatar
spedaleden
Thanks everyone
To Flywheel Question
