Setting belt tension
Old Sep 3, 2011 | 09:57 PM
mark79,80's Avatar
mark79,80
Default Setting belt tension
Very basic question but could use help:
How do you determine the correct belt tension without any special tools?
Specifically, tension for the AC compressor belt and the alternator
belt on a 1979? Seems like the tension for longer belts needs
to be tighter to get the same flex in the center as shorter belts,
but don't want to overtighten and damage bearings.
Old Sep 18, 2011 | 08:17 PM
rainmaninwa's Avatar
rainmaninwa
Set the belt tension as loose as you can get it and not have the belts squealing under load.
Overtightened belts cause all kinds of interesting problems.
Old Sep 18, 2011 | 11:18 PM
7T1vette's Avatar
7T1vette
For a belt with a long 'free' span between pulleys, there should be about 1/2" deflection when you depress that belt in the center of a long span with the end of your finger. That deflection should be with moderate pressure applied...no wincing and no pain allowed. If it is any tighter than that, you run the risk of overloading the bearings in the accessory it is driving.
Old Sep 19, 2011 | 09:26 AM
69 Chevy's Avatar
69 Chevy
Krikit gauge is a cheap tool unless you have a 'calibrated thumb.'
http://www.youtube.com/watch?v=z11wfc-0-hY
To Setting belt tension
