difference 350 vs 400 auto
Old Sep 6, 2011 | 09:35 AM
Ferrolanoman's Avatar
Ferrolanoman
Active Streak: 90 Days
Default difference 350 vs 400 auto
I'll be looking at a '72 small block coupe later this week and the owner can't tell me if the auto transmission is a turbo 350 or a 400. What are the external differences that I can look for to identify it? It's not an original engine car, so what it came with from the factory doesn't necessarily apply here. If someone could post a picture of the transmissions or provide me with some clues, I'd sure appreciate it!
TIA
Old Sep 6, 2011 | 09:37 AM
sstopczy's Avatar
sstopczy
Just use Google and look at the images for each. They have different pans that you should be able to see difference pretty easily.
Old Sep 6, 2011 | 10:10 AM
Vette5.5's Avatar
Vette5.5
The output shaft on a 400's also a larger diameter. These tranny's weigh more and sap more power. Also, the vacuum modulator position tends to get in the way of the right side exhaust piping. Nothing at all wrong with a well built 350.
Old Sep 6, 2011 | 12:19 PM
7T1vette's Avatar
7T1vette
The oil pan on the THM-400 resembles the state of Texas ; the THM-350 pan is generally rectangular. The modulator on the 400 is on the right side just above the pan split-line; the mod on the 350 is at the right-rear, I believe.
Old Sep 6, 2011 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
TH350 was not available in 72; TH400 was optional. If the car is factory auto, and if the tranny has not been swapped, you should find a TH400.
Old Sep 6, 2011 | 02:58 PM
Ferrolanoman
thank you all very much for your help. so, here's hoping that whoever changed the engine also switched the 400 for the 350! I'm anxious to check it out.
Old Sep 6, 2011 | 03:42 PM
dstaley's Avatar
dstaley
There's nothing wrong with the TH400, don't be afraid of it. It weighs a whopping 9 pounds more than a TH350. They both use the same torque converters, and although the rotating mass is slightly greater in the TH350 it isn't enough that anyone short of a professional race team can tune an engine well enough that the difference can be measured in parasitic loss. People run 10 second quarters pretty regularly with TH350's and 9 second cars often have TH400's. so they can both be very fast.
I wouldn't be afraid of either one of them.
EDIT: Oh, and one other significant difference between them- a TH350 uses a cable connected to the carburetor for passing gear (kickdown) control, while the TH400 uses an electrical solenoid, with an electrical switch on either the carburetor or the pedal. If there's a cable running from the bottom of the throttle linkage down to the transmission, it's a TH350. If it's not there and passing gear works, it's likely a TH400.
Last edited by dstaley; Sep 6, 2011 at 03:45 PM. Reason: Another difference between transmissions
Old Sep 6, 2011 | 03:46 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Ferrolanoman
...here's hoping that whoever changed the engine also switched the 400 for the 350!...
That's not the way you want to go. Let's hope no one swapped the engine and you want the TH400.
Good luck.
Old Sep 6, 2011 | 07:27 PM
7T1vette's Avatar
7T1vette
The 400 is a little less efficient than the 350; but, the 400 is bullet-proof...the 350 is not (unless it has some upgraded 'guts').
Old Sep 6, 2011 | 09:41 PM
'75's Avatar
'75
Old Sep 6, 2011 | 11:04 PM
7T1vette's Avatar
7T1vette
Good visual display. Now that I look at them again, I think the pan on the 400 looks more like Illinois....
Old Sep 6, 2011 | 11:28 PM
Ferrolanoman
You guys are the greatest! Thanks very much for the seminar. I'll download and print a few copies to have as reference for present and future use.
Old Sep 7, 2011 | 02:30 AM
Sunstroked's Avatar
Sunstroked
I put a 400 in my old camaro after breaking the 350. It was a B&M trans and it took all the abuse I could give it. Never had a problem with it. I would be inclined to hope for the TH400.
To difference 350 vs 400 auto
