Tansmission/engine alignment problem.
Old Sep 8, 2011 | 12:55 PM
builder's Avatar
builder
Default Tansmission/engine alignment problem.
On my '69, I am upgrading to a 700R transmission. Now that I have the engine and trans in place with all the mount bolts inserted, but not tightened, the rear of my transmission (the knuckles) seem to be too close to the driver's side of the tunnel. Nothing else is installed yet (exhaust, pumps, etc.) I can shift it over a bit, but it wants to move back to that position. I have tried to reposition the engine mounts and have taken the bolt out of the trans mount to see if that was holding it in place. The only thing I can think of is the new poly engine mounts might be "off" a bit. I had planed on switching the two engine mounts from right to left to see if that makes a difference.
Has anyone run into this problem before?
Old Sep 8, 2011 | 01:46 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
roger that buddy.....just enough space to get your finger knuckle up there....i seem to remeber elongating one of the trans mount holes for better alignment of the cross member....been like that for several years with no issue.. let me get some pics
Old Sep 8, 2011 | 02:04 PM
jnb5101's Avatar
jnb5101
i had the same problem. turns out the frame is just a bit out of straight due to 40 years of use. i had to have a helper push the trans nose to one side to get the mounting bolts started. runs true and vibration free now.
Old Sep 8, 2011 | 02:13 PM
builder's Avatar
builder
I would rather get it true without placing the stress on the mounts. I don't believe I have a frame issue unless it came from the factory that way. This car has been in dry storage for 25 years. I would like the trans/engine to sit in place naturally.
Old Sep 8, 2011 | 10:18 PM
bobs77vet's Avatar
bobs77vet
i think it suppose to be on a slight angle....pushed over to pass side at the end of the trans
Old Sep 8, 2011 | 10:31 PM
sly vette's Avatar
sly vette
I believe the drive train is offset by an inch towards the pass. side but it should NOT be on an angle. The drive train should run parallel to the frame rails.
When I restored my '69 I found that the right side Eng. mount horn was approx. 1" rearward of where it should have been so I took accurate measurements of the frame from all reference points, thinking the frame was bent, and the frame checked out to be perfectly true.
The horn must have been welded in an improper location from the factory is the only conclusion I could reach at that point.
I removed the horn and placed it in a position where the drive train was parallel to the frame rails and welded it.
All has been good now for approx 15,000 miles.
Old Sep 9, 2011 | 11:21 AM
7T1vette's Avatar
7T1vette
Ditto on the 'fit' problems with the 700R4. In my case, there is just enough clearance to assure no rubbing/impact from the drivetrain.
You might follow the suggestions above (pry the tranny as far to the left as possible, then tighten the rear mount bolts...the ones going to the transmission AND the ones on the rubber mounts), THEN loosen the engine mount bolts to see if it will shift a bit to your advantage.
If you get it all tightened up and there is any clearance at all, it should be fine. All of the drivetrain components are mounted to the frame, so there shouldn't be any movement/shifting afterwards. {At least, I've not had any.}
Old Sep 9, 2011 | 04:32 PM
builder's Avatar
builder
OK. I understand that. Mine is closer to the driver's side of the tunnel. NOT!
I misspoke. It is closer to the passenger side.
Old Sep 9, 2011 | 09:27 PM
7T1vette's Avatar
7T1vette
You might have a frame problem or mislocation of one or both motor mounts.
Old Sep 9, 2011 | 10:42 PM
sly vette's Avatar
sly vette
Even with the,offset the trans. should run straight down the tunnel with the same amount of room on either side.
To Tansmission/engine alignment problem.
