passing gear linkage?
Old Sep 9, 2011 | 09:32 PM
McVette's Avatar
McVette
Default passing gear linkage?
Ok guys I just noticed my passing gear linkage was not hooked up on the vette I just bought a couple weeks ago, the motor is a crate motor that was put into car about 2 years ago and driven less than 2000 miles. I am wondering if it was left off by accident or could there be some reason why it was left disconnected, also the springs to pull the throttle back was also left off, that is part of the reason why i think maybe it was left off by whoever installed motor....just wondering if there is anything I might need to look for before i hook it back up. I will try and post a couple of pics in case I did not describe it clear enough here.
Old Sep 10, 2011 | 10:53 AM
71scgc's Avatar
71scgc
What transmission are you running? TH350 will have a mechanical linkage from the carb to the trans. TH 400 will not. It's kickdown is electronically controlled, either at the carb, or more commonly, at the accelerator pedal.
Old Sep 10, 2011 | 11:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by McVette
...just wondering if there is anything I might need to look for before i hook it back up...
The AIM shows the installation. Purchase the AIM and take a look at the diagrams.
Old Sep 10, 2011 | 05:11 PM
McVette's Avatar
McVette
its a TH350 and I was just asking if there was any known issues of any problems that someone would know of why it would have been left off............or by accident
Old Sep 18, 2012 | 07:10 AM
vittetoetim@yahoo.co's Avatar
3rd Gear
i have an 82 CFI i just bought also and was wondering why it has no passing gear, someone said it was the linkage probably not hooked up can anyone explain about this linkage???
Old Sep 18, 2012 | 09:45 AM
damoroso's Avatar
damoroso
That's because they don't know what they're talking about. Your transmission uses a shift cable and a TV cable, it they weren't hooked up, you'd have real problems. The shifter cable selects the "gear" and the TV cable controls pressures in the valve body depending on throttle position, and it's likely not adjusted correctly. This is a critical adjustment, I'm guessing from your question you're not that familar with this trans so, if you take it to a trans shop, they should be able to do the adjustment for you, it'll only take a couple minutes. If everything else is working properly, and they try to sell you a rebuild, you need another shop.
Old Oct 3, 2012 | 05:03 AM
3rd Gear
thanks damaroso youve been the most help.......is this adjustment you are talking about located near the rear firewall? and what they refer to as the ''detent adjustment? ??
Old Oct 3, 2012 | 11:18 AM
texas jim's Avatar
texas jim
Just hook up the down-shift cable, it's no big deal. You set it at WOT or very near. If you have a manual, it should show you how to adjust it. If it's not hooked up, from my understanding, even if you shift the trans into 2nd., fluid pressure will be low and the trans won't perform properly.
Is the correct cable hook-up (linkage) there on the carb
Old Oct 3, 2012 | 12:17 PM
MelWff's Avatar
MelWff
There is a clip on the cable at the bracket on the carburetor. Open the clip, have someone completely depress the gas pedal to the floor, make sure no floor mat is in the way, and then close the clip while the pedal is still to the floor.
Old Oct 3, 2012 | 12:25 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://forums.corvetteforum.com/c3-t...post1581856825
To passing gear linkage?
