LS3 into my 72
Here is the front of the console gauges lit up. You can see the check engine light(from an 82) and all the gauge lights work. They are all pegged due to no sender being hooked up yet. The bright light will be for the high beam indicator. Might have to tone that one down a bit as it is very bright.
Here you can see the two main gauges and the wiring. New head light switch and oh yea I put in electric headlights also to ditch all the vacuum operated things.
Here is the new console. With the T56 sitting a little further back I elected to not put in a goofy shift arm and just move things back. Also it has the electronic controls for the VA system.
Here is the console gauge back all cleaned up wire wise and ready to install. I'm no electrical engineer but it all works and is an easy plug and play.
I did the same thing with my gauges- much better idea than disconnecting 17 wires!!!
Richard
Eddy
This is one of those non glamorous parts that needs to be installed. The LS3 motors and a lot of the LS motors when run hard suck the oil mist out of the motor and into the PCV system. So the cure is a catch can that removes most of the oil. I bought this a few years ago and never got around to installing it. This was for a C6 Corvette and had a bracket to mount it. Well mine not being a C6 was not going to fit at all. The VA compressor is also in the way. So I had to find a spot that was not looking like it was just tossed in the engine and ran the hoses where they are barely visible. Takes time to plan and execute this stuff. I spent probably 4 hours doing this. Nobody will ever notice and it is not a pretty thing but the car will run better without the oil mist blowing around in it. So its the little things like this that take your hours up but it is done right. One more project done and out of the way. It is mounted down low on the passenger side inner fender skirt. Just below the ECM
Eddy
As you can see I got my new Tanks inc tank in. I used the different sending unit for fuel tank level. It uses a ball instead of a float. Supposed to be less fuel needle movement when fuel is sloshing around. Also this is the 4th fuel tank I have gotten from Tanks. Each time I notice the fuel baffling in the tank is better than the previous. This should stop fuel starvation in a long corner.
Fuel pump in. Sender in. Wired up with weatherpack connectors ready to plug and go. Waiting for 3 fuel line fittings then back in it goes.
i bought a catch can recently. How did you plumb yours? I've seen/read so many opinions and options. Some run 2 cans,1 for the clean and 1 for the dirty side. Any thoughts?
Ryan
On the dirty side I pull the dirty air from the factory nipple on the plate below the intake on the flat plate that covers the lifter valley. Again the factory draws it from here. From there a vacuum line to the intake side of the oil separator then back to the factory nipple on the passenger side of the throttle body.
Most of the oil I have seen has been on the dirty side of the system in the floor of the intake manifold so this way should separate it before if goes back into the intake. If you want some pictures I can take it.
I'm curious as to where you got the connectors? I've found only a couple of different types, either weatherpack, or Molex style. These look great and seem easy to work with.
TIA!
Paul
TIA!
Paul
to you!Those would be nice to see!
Happy Cinco de Mayo all!
Can you walk me through where you tied into the harness? I finally got the OBDLinx to work (ground problem
) so I can get info from the ECU but it doesn't have oil pressure or temp and those are the things I am most worried about. When my header wraps started smoking/curing I was sure that I was over heated and about to ruin the whole thing!Thanks,
Mike
Careful on the over heat you may have an air block in the cylinder head.
I used the wiring harness from PSI. It is pretty much a stand alone harness. As said above the gauges are run separately from my PSI harness. I did buy the expensive tach harness from summit and run the electronic speedo off a GPS signal. Works well. I got the idea when I did this on my Cobra also. The console gauges use some of the original wiring but things like oil temp have separate wiring. I was fortunate to have the harness out of the car on mine and Davids and was able to lay it out in the basement.. I unwound a lot of the tape and used some of the original and added where needed. Once it was al set I rewrapped the harness so it is neat and looks correct. If you need any more info let me know.
