Fuel Pump Question
Old Sep 11, 2011 | 06:05 AM
AAJC's Avatar
AAJC
Default Fuel Pump Question
I think my fuel pump might need a little work.
I have been making slight adjustments to my Q-Jet & getting a little better response.
When I am at WOT in 1st, 2nd, and even 3rd, the engine pulls strong & smoothly.
In 4th, the engine doesn’t want to pull smoothly, almost feels like its missing. As the revs get higher its starts to smooth out.
In 5th gear I cant get it to go past 100 mph. Feels like its missing again. & not enough torque to get the revs up.
Could I be draining the bowl because the pump isn’t keeping up?
Thanks in advance.
Andrew
Old Sep 12, 2011 | 01:02 PM
MelWff's Avatar
MelWff
check the float level first. Then check your total timing at 3,000 rpm assuming you recurved your distributor.
Old Sep 14, 2011 | 06:55 AM
AAJC's Avatar
AAJC
Thanks MelWff.
I will have to read up on the float level.
Andrew
Old Sep 14, 2011 | 07:10 AM
Tim H's Avatar
Tim H
You need a fuel pressure gauge to see if your loosing pressure at high rpm.
Old Sep 14, 2011 | 08:05 AM
7T1vette's Avatar
7T1vette
Sounds like fuel starvation. Float level too low (top of float should be about 5/16" below the upper edge of the float bowl, when you depress the float pivot pin downward and gently seat the needle by pushing the float end down); kink in rubber hose at fuel pump; damaged/pinched fuel line (rubber or metal); fuel filter clogged (internal carb filter or in-line filter); clogged strainer sock at fuel tank outlet.
Less likely to be ignition, air inlet restriction, or valve train related as the engine revs up fine in lower gear ranges.
Old Sep 14, 2011 | 09:24 AM
billla's Avatar
billla
St. Jude Donor '14
On a Q-Jet, the internal fuel filter is the first check, as that one often never gets changed as many folks don't even know it's there...
To Fuel Pump Question
