Water in gas, repeating issue
Old Sep 11, 2011 | 11:49 PM
WA4DBY's Avatar
WA4DBY
3rd Gear
Default Water in gas, repeating issue
I am having an issue with water in my gas tank. Each time that water somehow ends up in the tank, I pump out the fuel until there is no more water coming out. However, it always seems to start missing and lagging a few months after, and it turns out to be water in the gas. For reference, the carb is a Holley 4160 600cfm. When I feel inside the tank, there is what seems to be condensation inside the tank. The tank has not been filled to the top in a few months, it usually stays around 1/4. Has anyone else had this problem? The car is stored outside. I doubt that is the gas, as my lawn / garden equipment, as well as a 75 vette, get gas from the same station. Any and all help is appreciated. The carb is around 3 months old, and really don't want to have to clean water out of it.
Thank you
Old Sep 12, 2011 | 08:52 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Don't know where you are but a partially filled gas tank is just ripe for condensation. Keep your tank full of gas, keeps the amount of moisture getting into the tank to a minimum.
Old Sep 12, 2011 | 09:10 AM
wombvette's Avatar
wombvette
Only two ways for significant water to get there, either was in the gas when you put it in there or came in through the filler neck after. Usually the drain hole in the boot under the filler neck is stopped up and water backs up over the neck. It is a common problem. Open that hole, cut out a chunk so the damn thing don't stop up, or best, remove the boot completely. It will stop the problem.
Old Sep 12, 2011 | 12:58 PM
rugerm44's Avatar
rugerm44
If your using ethanol put some fuel stabilizer in it made for marine use.Keeping the tank full will certainly help.I do both and have never had an issue with water.Temp fluctuation and having a 1/4.tank of gas is ripe for condensation.
Old Sep 12, 2011 | 01:07 PM
7T1vette's Avatar
7T1vette
I agree that a plugged drain hole in the boot around the filler neck (just under the gas cap) will cause you to get water in the tank every time it rains and/or whenever you wash the car. Use a long piece of wire to run through it and remove any blockage. If this is your problem, you also need to check the status of the fuel cap gasket [assuming you have a non-vented gas cap].
You can also put some alcohol in the fuel tank. Alcohol will allow water to dissolve (or mix) with gasoline. If there is not too much water in the tank, the fuel will burn fine with the extra water in it.
The other possibility is that you have a neighbor who doesn't like you or your car!
Old Sep 12, 2011 | 01:42 PM
richardttu's Avatar
richardttu
I agree completely with 7T1vette. however, I would not remove the boot from the filler cap, as a previous owner did that to the Corvette I now own and the top of the gas tank rusted out. Which made for an even bigger mess for me to fix. Just my two cents worth.
Old Sep 12, 2011 | 03:27 PM
wombvette's Avatar
wombvette
I will bet you that it will rust from the inside much faster than the outside. The top is slanted and will dry off quickly, unless you keep it outside in a region that is ultra wet, I dont think outside tank rust is much of a problem. It could increase the chance of rust under the padding and straps. I will chance that in order to keep the other things like lines, and carb from failing from all of the internal rust. I agree that keeping the drain clean is a better solution than removing the boot, but most don't think to check it and they get water when the drain stops up, and it don't take much to stop it up. Another stupid design that causes expensive problems.
Old Sep 12, 2011 | 03:46 PM
MelWff's Avatar
MelWff
Cannt seem to find what year car you have. I know certain years, such as 1969, used a cork gasket between the neck and the tank. If the gasket breaks up and water gets on the top of the tank it will run into the tank.
Old Sep 12, 2011 | 04:25 PM
Ironcross's Avatar
Ironcross
the logical choice except you need not remove the rubber boot surrounding the gas cap just clean the drain hole out.......and they all have one
Old Sep 12, 2011 | 06:08 PM
WA4DBY's Avatar
WA4DBY
3rd Gear
The car is a 74. Going to check that drain hole later, and post the results.
Old Sep 12, 2011 | 07:02 PM
mold99's Avatar
mold99
A c3 doesn't have to be very old for this to happen. happened to my 71 lt1 when only 2 years old. boot filled up in the rain and the gasket had a ripple in it. got a lot of water in the tank. check the fuel cap, gasket, and the boot drain.
To Water in gas, repeating issue
