Corvette Stingray 1971
Old Sep 20, 2011 | 11:56 AM
CStingray71's Avatar
CStingray71
Default Corvette Stingray 1971
Hi Guys .. My Car Stingray 71 So Many PAsts on ENGINE .. i Want to KNow How Much Horse Power it make .. Complete Engine 350 Rebuild - New Valves - New Timing Chain - New 6-series MSD Ignition - New MSD Billet Distributor - New MSD 8.5mm Black Super Conductor Spark PlugWires - New Comp Cams ‘Xtreme Energy’ Hydraulic Roller Camshafts - New Comp Cams Dual Valve Springs - New Comp Cams High Energy Hydraulic Roller Lifters - New Comp Cams Rocker Arm Studs - New Comp Cams Pushrod Guideplates - New Rocker Arms - New Pistons - New Crank - All New Seals and gaskets - New 327 Oil Pump - All new bolts - New Oil Pan Set - New Connecting Rods - New Edelbrock Performance Intake Manifold - New Holley Classic Double Pumper Carb - New Water Pump - New Engine Mounts - New Fuel Filter - New Carburetor studs - New Fuel Lines .. Thanks alot .
Old Sep 20, 2011 | 12:02 PM
bashcraft's Avatar
bashcraft
286 hp
Is something wrong with your "Shift" button? That's friggin annoying to read.
Old Sep 20, 2011 | 12:06 PM
Ganey's Avatar
Ganey
The cam is going to make a big gain. There is not enough info. like which heads, intake, Holley & exhaust like headers. So about 300HP+ w/ the orig. info. posted.
Old Sep 20, 2011 | 12:07 PM
CStingray71
thanks alot
Old Sep 20, 2011 | 12:18 PM
69 Chevy's Avatar
69 Chevy
New Carburetor studs. Those will make the biggest difference of them all. Except maybe that 327 oil pump.
Old Sep 20, 2011 | 12:42 PM
rugerm44's Avatar
rugerm44
Dudes been hanging in the hood to long or under it.
Old Sep 20, 2011 | 12:44 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by CStingray71
thanks alot
For what?
Old Sep 20, 2011 | 01:28 PM
Alan 71's Avatar
Alan 71
Hi CS71,
Since you're a new member, WELCOME!!!
As you see it's pretty fruitless to try to guess h.p gain from just a list of parts.
I'd enjoy seeing some picures of your 71 since I'm a 71 fan!
Regards,
Alan
Old Sep 20, 2011 | 01:48 PM
Gordonm's Avatar
Gordonm
What cam and heads. Most of the stuff you talked about will gain no horse power at all. What is a 327 oil pump anyways. Makes no sense at all.
Old Sep 20, 2011 | 05:38 PM
7T1vette's Avatar
7T1vette
You didn't mention that you were changing the heads. And, if you don't, there's no reason to do all that other "stuff" you listed above. Putting a high-lift cam in an engine...without changing the heads...is like putting a high volume water pump into a system without increasing the size of the line out of the pump!! It makes no sense to do such a thing.
Heads and [compatible] cam change will make the biggest HP change to your engine. Then you need to open up the exhaust with duals, and headers, if you have the funds. You can gain a bit more with an intake manifold; but changing the carb will make no HP improvement. The rest of the stuff you list is "nice to have", but won't really impact engine power unless your present ignition system is faulty.
Old Sep 20, 2011 | 07:55 PM
Ganey's Avatar
Ganey
CStingray71
You have to watch out for the stock guys who may make up anything which basically says "leave it stock" as you may have noticed.
To Corvette Stingray 1971
