Best Radiator?
Old Sep 20, 2011 | 11:22 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Default Best Radiator?
I not sure where to go on this element of my build. I'll be running a 200 4r with a fairly slippy TC, trans cooler, behind an 8.5-1 sb 406 & 8-71 roots.
What radiator & fan(s) combo can I run with reasonable confidence in cooling ability. I live in Tucson so summer afternoons, temps over asphalt in the sun get a bit hellish .
Old Sep 21, 2011 | 01:49 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Dewitt, I have one in my '71 BB and it keeps my engine cool in our 110*F summer.
Old Sep 21, 2011 | 10:34 AM
RobbSalzmann
St. Jude Donor '12
Thanks HamadUP.
Does your setup have fans? I'm hoping I don't have to lay out $1600 for a radiator setup that works. If I have to I will, but I'm hoping there are more economical yet effective solutions out there.
Old Sep 21, 2011 | 10:40 AM
54greg's Avatar
54greg
Dewitts here also. They have a great fan kit also.
Old Sep 21, 2011 | 03:00 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Originally Posted by RobbSalzmann
Thanks HamadUP.
Yeah, I got the rad./fan combo, it even comes with a real nice relay/wiring assembly. It was so reasonably priced at $920, when you compare it to the top notch build quality, its maybe the best deal.
http://www.dewitts.com/pages/product...asp?ProdID=384
Old Sep 21, 2011 | 03:17 PM
Alan74's Avatar
Alan74
Cruising
Picked up DeWitt's with dual fan kit from Zip's Corvette on a 15% off $500.00 or more spent promo. Ended up being right under the $925.00 list but with shippinf and tax included. Keep an eye open fron those vendor promos.... every little bit helps.
Old Sep 22, 2011 | 09:32 AM
RobbSalzmann
St. Jude Donor '12
Thanks guys. Dewitt's w/ dual fans seems to be getting most of the votes. I'll check it out.
Old Sep 23, 2011 | 10:11 AM
Alan74's Avatar
Alan74
Cruising
Oh, the Dewitt's comes with wiring harness and 2 relays one per each fan. If you have A/C you will need 3rd relay to cut on fans when A/C is running. Just a heads up.
Old Sep 23, 2011 | 10:19 AM
1rino56's Avatar
1rino56
Just installing my Dewiits w/spal fans, relays, harness etc.. Good build quailty. Do not have the fans mounted until the rad is in the car. I bought all the componets seperate and saved about $150 from the 925price. Amazon!
To Best Radiator?
