oil pressure gauge bouncing
Old Sep 21, 2011 | 04:27 AM
mcmsmsc's Avatar
mcmsmsc
Default oil pressure gauge bouncing
wondering what would cause the oil pressure gauge to bounce in my 1977?
Old Sep 21, 2011 | 07:29 AM
Yeller81USNRet's Avatar
Yeller81USNRet
On my 81 the oil pressure guage bounces when it is idling but as soon as you give it some gas it evens right out. Steady pressure.
Ken
Old Sep 21, 2011 | 07:45 AM
jb78L-82's Avatar
jb78L-82
My 78 L-82's oil pressure gauge will move around slightly at idle (40-50 lbs) and will cruising going down the road (50-60 lbs). Always has for the last 28 years! How much does it move? I would guess it is normal. I run Mobil 1 15W-50 in a totally stock engine-never been opened.
Old Sep 21, 2011 | 08:10 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Ditto with my '76...
Old Sep 21, 2011 | 12:00 PM
7T1vette's Avatar
7T1vette
Some 'wiggling' is not a big deal. If it is really jumping around, there is a problem with the sender wire (wire almost broken thru and making intermittant connection with engine vibration) or a problem with the regulator valve in the oil pump (binding/sticking).
Old Sep 21, 2011 | 04:41 PM
C3Dave's Avatar
C3Dave
This is sounding pretty common. My 79/s oil pres will bounce between 45 and 50 at idle. Gauge stays at 60 anywhere above idle.
Old Sep 21, 2011 | 05:00 PM
80malibu's Avatar
80malibu
My '80's guage bounces at idle, settles down while cruising or under throttle pressure.
Old Sep 21, 2011 | 05:09 PM
mcmsmsc's Avatar
mcmsmsc
i think it is more of a jump and is seems to happen when under throttle and at cruising speed. more under throttle. at idle it is ok. i will try and check the wire.
Old Sep 21, 2011 | 05:45 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Are you positive your oil level is good? Does this happen even if sitting still in neutral?
Old Sep 21, 2011 | 09:26 PM
mcmsmsc's Avatar
mcmsmsc
just checked oil to make sure, just had it changed a month ago but you never know, its full probably a little to full maybe by half quart. it does bounce a little at idle. where is the sending unit?
Old Sep 22, 2011 | 01:53 AM
7T1vette's Avatar
7T1vette
Sending unit is mounted just above the oil filter on the left side.
Old Sep 22, 2011 | 10:41 AM
tshort's Avatar
tshort
CI 7-8 Veteran
On a small block the sending unit is on the "China wall" at the back of the block. Look near the back edge of the intake manifold and if it's stock you should see a brass tube connecting to the block.
Old Sep 23, 2011 | 03:56 PM
Stooney's Avatar
Stooney
Not to hijack the thread, but you guys are saying you have 50-60. I idle around 30-40, most I ever hit is about 50 lbs at higher RPM. Should I be using thicker oil? or is 30-40 alright. it's a 1980.
Old Oct 23, 2011 | 11:47 PM
briankeery's Avatar
briankeery
I'm with you Stooney, my '79 L48 has 131,000 Km on it, never been apart, and has the exact same readings as you......if it ain't broke, don't fix it......
To oil pressure gauge bouncing
