Wiper Door Problem
Old Sep 21, 2011 | 08:55 PM
vettecollector54's Avatar
vettecollector54
2nd Gear
Default Wiper Door Problem
I am currently having a problem with my wiper door on my 69 vette. It open and closes randomly. It does not matter whether the electrical wiper switch is on or off. Any help with this problem would be much appreciated.
Old Sep 21, 2011 | 10:15 PM
wombvette's Avatar
wombvette
Worse on acceleration?
Old Sep 21, 2011 | 11:49 PM
vetteguy22's Avatar
vetteguy22
Sounds like a vacuum leak.
Old Sep 22, 2011 | 07:59 AM
vettecollector54
2nd Gear
Default Wiper Problem
I have replaced all the hoses and have also replaced the actuator at the wiper arm. I have not replaced the wiper door actuator itself. When I reverse hoses on the actuator (the red and the green) then the door will stay down but then it won't come up. While I am driving it just goes up and down randomly.
Old Sep 22, 2011 | 08:48 AM
jnb5101's Avatar
jnb5101
remember that these vaccum systems are designed to open when there is no vaccum on the control relay. i'd test the relay first. the O rings in the slide are probably at fault.
Old Sep 22, 2011 | 10:19 AM
wombvette's Avatar
wombvette
Check the Check Valve.
Old Sep 22, 2011 | 11:43 AM
7T1vette's Avatar
7T1vette
If the check valve (in the main vacuum line off the intake fitting) is working properly, the likely culprit is the wiper interlock valve located below the right side wiper when it is parked. That switch lets the system know that the wipers are parked so that the door can be closed. If it is sending confusing signals to the system (due to internal seal leakage), the rest of the system will try to comply.
Old Sep 22, 2011 | 12:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Sep 22, 2011 | 10:48 PM
shrekviper's Avatar
shrekviper
I have the same problem even though I put in a brand new valve. I knew it didn't hold vacuum well, but it was all I had. They aren't the best produced pieces. Someone (Roger?) has been experimenting with ways to make them seal better.
Edit: It was Roger
http://forums.corvetteforum.com/c3-t...le-piston.html
To Wiper Door Problem
