Too much power?
Old May 2, 2002 | 02:47 PM
Koz
Guest
Posts: n/a
Default Too much power?
Is there such a thing as having too much power under the hood.. for street riding only.. I know it has a lot to do with learning how to tame or control the beast but can you have too much with a 350 or 396 motor? With my L48 stock motor I sometimes get a chirp and I'm not really trying to.. then again I could be just running over something.. but can these motors produce enough HP to force you to idle roll start before pedal.. or anything "more than required" pedal cause tire spin.. I don't mind WOT = tire spin.. cause that's what your asking for but un-asked for tire spin is what I'm thinking about.
Old May 2, 2002 | 03:20 PM
ZORA_RULES's Avatar
ZORA_RULES
Default Re: Too much power? (Koz)
Sounds like my kind of problem :jester Unfortunatley I've never had a car with that problem so I can't give you much help...does sound like the kind of problem I'd like to have though :D
Old May 2, 2002 | 03:22 PM
Fevre's Avatar
Fevre
Kinda like having too much $, never happens. :)
Old May 2, 2002 | 03:23 PM
Alwyn678's Avatar
Alwyn678
Default Re: Too much power? (ZORA_RULES)
U can never have to much power ask Merlin
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Too much power :confused: Sure, and you can have to pretty a wife also :lol:
dshrack's Avatar
dshrack
Its all about continous improvement.
My '81 with the original L81/4speed would spin the 20 year old 225/70R15s pretty easily when I first got it. Swapped out the engine for a 400+ hp SBC and I couldn't touch the go peddle without getting sideways. So I found a simple solution: 285mm wide tires made of the modern Z-rated compound and problem solved. I'll probably have the same problem again when I get my conceiled blower installed (*sigh*, someday). When that time comes, it will be time to improve the rest of the drivetrain to match. Technology keeps advancing- so should we.
Old May 2, 2002 | 03:24 PM
Scooter70's Avatar
Scooter70
Then your problem isn't 'too much HP", it's 'too little traction'.
I read somewhere once.... "When I can spin the tires from corner exit until the next corner entry, then I'll have enough horsepower."
Old May 2, 2002 | 03:40 PM
Lasse's Avatar
Lasse
Default Re: Too much power? (yellow 72)
Yellow, your Corvette is too awesome! :lol: Great!! :yesnod:
[Modified by Lasse, 8:41 PM 5/2/2002]
Old May 2, 2002 | 03:42 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Too much power? (Scooter70)
Nope, you can never have too much power. It's a matter of learning how much power to apply, and when to do it. Most times you need more HP as you go faster (to overcome aero drag). So you may have too much power for the tires at low speed but you need it all at top speed.
verskel's Avatar
verskel
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Yup - take it from a BB owner - even with the extra cubic inches - I still think it's 'underpowered' :lol: :lol: :lol:
Adequate power is enough to make you're tires instantly bald off the line - pin you back into the seat so hard that you loose your breath - you need 2 lanes for take off just to keep the beast in a straight line - and just when everything seems to 'calm' down - you hit 2nd Gear & start over !!!! :lol: :cool:
Old May 2, 2002 | 03:49 PM
67HEAVEN's Avatar
67HEAVEN
Default Re: Too much power? (burners)
I find mine drives best with the key turned off most of the time.
Old May 2, 2002 | 04:06 PM
Koz
Guest
Posts: n/a
Default Re: Too much power? (verskel)
:lol: :lol: :lol: Yup.. that's what I want.. :cheers:
Old May 2, 2002 | 04:44 PM
gkull's Avatar
gkull
Quote: Here's the million dollar stupid question: Given an engines CI wouldn't there be a scientific "best" cam for street with "best" heads to use? Or is that what makes doing this so attractive.. Options, Options and they you have more options...
For $39.95 you can buy the Desk Top Dyno program. The program is within a few percent when you put in the actual CFM flow rates at all the lift points for your heads intake and exhaust and input actual .050 cam event numbers. So the scientific part is all done for you. You can juggle heads and cam profiles and come up with a custom cam at what ever hp you want. With a 396 500 hp and 500 TQ would be good numbers to shoot for. It gives numbers for my 383 of 579 hp and over 500 ft/lbs of TQ. It's not enough power and I went to mild on the cam. So my next choice will be more cubic inches or a blower.
The only reason I have a 383 is because I was in a hurry to get my car on the road and I didn't want to wait for a custom 396 crank to be made. It was a bad move on my part. Some of the other posters are right on about bigger better tires and you have a learning curve on how to let off of the gas to go faster.
[Modified by gkull, 2:45 PM 5/2/2002]
Old May 2, 2002 | 05:08 PM
Koz
Guest
Posts: n/a
Default Re: Too much power? (gkull)
You have a 383 turning 579hp and over 500 ft/lbs of TQ and it's not enough power? But you also stated that with a 396 aiming for 500hp and 500 TQ would be good numbers to shoot for. WAZUP with that? :cheers:
Old May 2, 2002 | 05:18 PM
gkull's Avatar
gkull
I was saying for you or anyone else building a stroker 500 hp numbers are reasonable and it doesn't require lots of high dollar parts. I didn't want to be low rpm limited. So if I want to shift at 7500 rpm I can and do. I actually had 8000 rpm limit in mind when I bought my parts so 7500 isn't stressing anything.
Old May 2, 2002 | 05:27 PM
ZORA_RULES's Avatar
ZORA_RULES
Ahhh. Another reason to like the forum so much. There's so many that think just like me. I totally agree....someday!
Old May 2, 2002 | 05:42 PM
Darkness's Avatar
Darkness
Default Re: Too much power? (Fevre)
AMEN :D
Paul
To Too much power?
Old May 2, 2002 | 06:23 PM
MassVette's Avatar
MassVette
HUH? :lol: :lol: :lol: :chevy :chevy :yesnod: :yesnod: :yesnod:
Old May 2, 2002 | 07:24 PM
Clink69's Avatar
Clink69
NO Way , Never too much power. If I had unlimited funds :crazy: I would have at least 1000HP. I just got my 383 with about 460HP and its already not enough... I want some more, please sir I want more..... :D
:flag
Old May 2, 2002 | 08:03 PM
oger's Avatar
oger
Default Re: Too much power? (Clink69)
You can't have too much power just ability to use all of it. I had a friend with a Sunbeam Tiger it had a bunch of 289 in it. The thing would stay straight for about 5 ft. It really wasn't that fast just so squirrelly it would scare you.
