Electrical gone bad?
Old Sep 25, 2011 | 11:30 AM
desertdogs50's Avatar
desertdogs50
Cruising
Default Electrical gone bad?
Ok, after months of rebuilding the front end, I started putting everything back together, as I was getting ready to wire up the alternator, in a rush I forgot to disconnect the battery, rookie mistake.
As luck would have it, I brushed up against the mechanics blanket on the left bumper and it push my ALt battery wire against my alternator and then came the fireworks. Following a heart wrenching spark and smoke, I now have no power to the car. Yes the battery is fully charged and Yes I checked the fuse box. All good.
So with my limited experience I throw the question out, what next. Thanks for the help in advance.
Old Sep 25, 2011 | 11:39 AM
7T1vette's Avatar
7T1vette
You likely just burned up one fusible link. That is exactly what is supposed to happen with a major short that is accidental :o or if an accessory fails and has a complete short. The smoke was probably the fusible link insulation frying (it shouldn't catch fire as the insulation on fusible links should be non-flammable).
Other than the link's insulation looking blackened, you won't be able to see any visual difference; but the wire inside it will be gone/melted.
P.S. While you are going about that repair, it is an excellent time to install a battery disconnect [on the positive side, IMO].
Old Sep 25, 2011 | 02:46 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Your car year is not listed but I'm guessing the same... The link more than likely is located on the driver side by the firewall. What year?
To Electrical gone bad?
