intake manifold restoration
Old Sep 28, 2011 | 04:34 PM
StingrayLust's Avatar
StingrayLust
Default intake manifold restoration
Ok, since I finally got around to sending in my carb for a rebuild to SMI, I'm stuck here looking at my old intake manifold and noticing just how ugly it looks. So the question is, just how hard of a job is it to remove the manifold, have it blasted clean, repaint, and the reinstall? What is the best paint to use or do people have them powder coated?
It's just the stock manifold for my Rochester qjet. Is there a better intake I should be using instead with my qjet? My coupe is a base model.
Here are some pictures of the ugliness:
Old Sep 28, 2011 | 04:41 PM
MelWff's Avatar
MelWff
how about this
http://www.summitracing.com/parts/SUM-226008/
Old Sep 28, 2011 | 04:51 PM
billla's Avatar
billla
St. Jude Donor '14
You could upgrade, but I'd double-check on what's going to fit under your stock hood.
It's not a big job to R&R the manifold - 2-4 hours on-and-off.
Otherwise, the manifold restoration is pretty easy. You will want to remove the heat shield on the bottom by removing the rivets. Then get it blasted and either powdercoated or painted - you'll have to make a judgement call on how close to the factory paint you want to get. Reinstall the heat shield by tapping the holes for screws.
Old Sep 28, 2011 | 04:57 PM
StingrayLust
Do I need to drain some coolant before pulling it off? I've never done this before so it's all new to me. What does this heat shield look like and why would I need to take it off?
Old Sep 28, 2011 | 05:04 PM
billla's Avatar
billla
St. Jude Donor '14
A sevice manual is a very, very smart investment
Yes, you'll need to drain the coolant as there's water in the manifold.
The heat shield is just a bit of tin on the bottom of the manifold. It's intended to keep hot oil off the bottom of the plenum to avoid heating the intake charge. It fills with a very hard goo that kind of defeats the purpose. You can just take it off and leave it off if you choose...but you really need to clean all that garbage out.
It's also a chance to address a lot of other service issues like vacuum hoses, etc.
Old Sep 28, 2011 | 05:35 PM
7T1vette's Avatar
7T1vette
If I were you, I would just mask off the throttle openings (duct tape for better strength), cut an opening in an inexpensive [paper] drop cloth to use for masking off the intake from other 'stuff', vacuum/clean off the top of the intake and spray paint it with Dupli-Color engine enamel (good to 500*F). You can remove the distributor or leave it there and mask around it.
Allow fresh paint to cure at least 2 days to be sturdy enough for reassembly. Full cure takes about 7 days.
Old Sep 28, 2011 | 08:06 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
not worth removing just to clean and paint.
only remove if your replacing it.
get some degreaser and clean and paint in place.
Tin foil works great to mask off / protect parts you do not want to paint.
Old Sep 28, 2011 | 09:20 PM
imariver's Avatar
imariver
If you do remove it, DO NOT...... have it blasted, (as you put it) Take 7T1vette's advice!
M2C Steve
Old Sep 28, 2011 | 09:34 PM
billla's Avatar
billla
St. Jude Donor '14
If it's iron - not aluminum - blasting isn't an issue And if it's getting painted, a light media or glass-bead isn't going to mar the surface from a restoration perspective.
I've never seen so much to-do over removing an intake - I must do it too often to think it's a big deal
Old Sep 28, 2011 | 09:42 PM
boltnut's Avatar
boltnut
Yea. Paint stripper and some elbow grease. You'll be happy with the results. I know lots of guys are reluctant to pull the distributor, drain some coolant and unhook hoses but it really is easy. The hardest part for a " newbie " is the distributor pull. And that's not too bad if you are careful....
Old Sep 28, 2011 | 10:37 PM
bpassmore's Avatar
bpassmore
I agree with 69Vett, use degreaser and scrub it down, mask with aluminum foil.
You should drain coolant to do a better job on the front end. Remove the choke stove on the right side and clean it up, paint with high temp silver would be a good touch. Who knows, you may be able to do something with the front of the motor while you are at it. You could spray some engine paint into a container and use a brush, I've done that several times and it works fine without a mess. (Paint remover may make a mess.)
Old Sep 28, 2011 | 10:41 PM
boltnut's Avatar
boltnut
IMO. Masking off the engine compartment and hoping you don't get overspray is more work than pulling and intake off.
Old Sep 28, 2011 | 11:07 PM
another-user's Avatar
another-user
its such an easy job, id just pull the intake and blast it. the powdercoat or paint.
Old Sep 28, 2011 | 11:09 PM
billla's Avatar
billla
St. Jude Donor '14
And the results won't be as good...and the gunk will still be under the plenum.
...but the last time I made a comment like that I really torqued someone off
Old Sep 29, 2011 | 01:53 AM
StingrayLust
I've replaced the distributor already, so I've gotten over that fear. I think my main concern is really what happens if I break a bolt. From all I know about this car when I bought it, which isn't much, the bolts may have never been removed. I've broken a few bolts on this car but most were exposed and rusty. Since I'm going with a show quality rebuild of my carb, it's going to look out of place on this crusty intake.
Does anyone have pictures of their intake where they left it on the car and just used paint remover and cleaned it before painting?
It's not an aluminum intake, it's the stock steel intake that I presume came with the car. Taking it out and having it glass beaded then painted sounded like the best option as far as looks go.
Old Sep 29, 2011 | 02:02 AM
another-user
ive got some pictures from a few years ago when i did that. looked great for about 6 months, then it all started cracking and peeling off.
i cleaned and spray painted the motor in the car once, and i will never do it again. it takes more work and effort to do it in the car, and its a poor finish. compared to doing it out of the car and stripping it down fully.
Old Sep 29, 2011 | 02:09 AM
StingrayLust
True, in looking at it, it does seem trivial. All it should be is remove 8 or so bolts, pry it from the block carefully, clean it, paint it, 4 new gaskets with some RTV, and torque to specs with new bolts.
However for someone who's never done something like this before, I want to know what the water's like before jumping in. So yes I'm baring my newbness to the world. I'm not sure if it's just breaking a bolt that's holding me back or just the "I've never done this before" fear.
I had roughly the same fear before I tore apart my front suspension. But in that case, I new a place I could easily get cheap parts, and the main bolts holding to the car were huge and were of little risk of snapping. If I were to break a bolt in my intake, I'd have no idea of how tough it may be to get it out and just pulling the engine out isn't something I can do in my current setup.
BTW, the front suspension turned out great and that fear is gone if I had to do it again.
PS - do I have to drain all of the coolant or just enough to drop it down so it doesn't leak all over the place when I remove it?
To intake manifold restoration
Old Sep 29, 2011 | 02:17 AM
StingrayLust
So you redid yours without removing the intake? I'd love to see any pictures you have. Do you think if you would have had it blasted and then painted it would have lasted longer?
But this also brings up a good point, maybe this is a lot of work for nothing as it will just look somewhat this bad in a year from now?
Old Sep 29, 2011 | 02:20 AM
another-user
should just be enough so it doesnt leak out when you pull the it off. personally, id just open the petcock and let it all drain out into some clean buckets and put lids on it. as long as it still looks clean and useable, id strain it and just dump it all back in the car.
if your intake bolts are like mine, theyll be loose as hell already. just put a wrench on them and give it a go. youll get a pretty quick idea if theyre going to come out or not.
Old Sep 29, 2011 | 02:35 AM
another-user
this is where i just started cleaning all the crap off for the first time
after spray bombing, and way too many hours of work. picture taken 7/7/09
april of 11, maybe 1500 miles later. its hard to see, but the front of the block and heads has alot of paint lifting already.
and finally, 1st of sept. after the block and heads were wire wheeled down to shiny metal, heavily degreased about 100x over, metal etched, primed, and painted. i couldnt tell you what this will look like a year or two from now, but i sure hope it still looks this good.
with all this said, my front and rear suspension still look great over all. the rear suspension is about 3 years old, front is 2. every piece on there was blasted, primed, and painted with rustoleum. id be willing to guess that those components are going to take a hell of alot more beating from the elements and the road then the motor will ever see, and just with the blasting, painting and priming, theyve held up 10x better than the spray bombed motor did.
