alternator
Old Oct 9, 2011 | 04:04 PM
oilcanharry's Avatar
oilcanharry
6th Gear
Default alternator
Have a mostly original 69.Big block 427/435 with 3-2's.Might need a new alternator.Looked on line and saw some from Corvette Central,corvette America and Advanced Auto.From that, I believe I need 100amp(No power steering or air in car.)Any thoughts as to brand etc.?
Old Oct 9, 2011 | 04:14 PM
Mike Ward's Avatar
Mike Ward
Your car came with a 61 amp. Why do you want/need anything bigger?
Old Oct 9, 2011 | 05:01 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
keep your orginal, and have it rebuilt.
Old Oct 9, 2011 | 05:50 PM
7T1vette's Avatar
7T1vette
Just rebuild it yourself; it's very easy to do. If you don't have a bearing problem at the front end, you don't even have to remove the nut/pulley. Just disassemble from the back side, swap out diode packs, replace the brushes with new ones, and put a little grease/lube in the rear bushing. You can buy rebuild parts at some auto parts places, from a starter/alternator rebuild shop, or over the internet.
P.S. Those two little holes in the rear housing are for paper clips: installed to keep the new brushes in their guides until the housing is assembled back together. Then remove the paper clips.
Old Oct 9, 2011 | 07:53 PM
sly vette's Avatar
sly vette
I agree.
Dollar for dollar this is a very easy fix.
Old Oct 9, 2011 | 09:53 PM
restoman1's Avatar
restoman1
Harry, the 69 alternator is a one year only, so if yours is original, keep it and rebuild it. They're going for BIG bucks on ebay! HERE'S an example of the 1100825.
Ed
Old Oct 10, 2011 | 02:29 PM
Ironcross's Avatar
Ironcross
427/435 with no PS or PB should be a 37 amp alternator.......435`s were never built with factory air.....61 amp alts are for factory air
Old Oct 10, 2011 | 02:35 PM
restoman1's Avatar
restoman1
The standard alternator for the 69 Corvette was rated at 42 amps, but the K66 Transistor Ignition was a required option with the L71, so the 61 amp alternator was used.
Ed
Old Oct 10, 2011 | 03:41 PM
Mike Ward's Avatar
Mike Ward
And for TI which I believe the 435s had.
Old Oct 10, 2011 | 07:52 PM
Duane4238's Avatar
Duane4238
If you rebuild it yourself, great! If you take it to a local shop for a rebuild, make sure you mark it and get your original back when done.
Duane
Old Oct 11, 2011 | 02:46 PM
Ironcross's Avatar
Ironcross
The TI ignition did not use a 61 AMP alternator when a 435/427 was ordered.....with which TI was standard in both the L-71 and L-88 and optional in every thing else........no need for a 61 amp alternator in a 435 as none were AC equipped......how do I know, .....I ordered one and still have it....#13092......
Old Oct 11, 2011 | 04:17 PM
restoman1's Avatar
restoman1
The 427/435 IS the L-71.
Ed
Old Oct 11, 2011 | 04:26 PM
Ironcross's Avatar
Ironcross
Ed
where did I say it wasn`t.?...I own one!......
.............just picked up from Merolis Chevy, March 1968
Old Oct 11, 2011 | 04:37 PM
restoman1's Avatar
restoman1
Well then, I'm confused at your reply. Why did you write the "TI ignition did not use a 61 AMP alternator when a 435/427 was ordered", when TI was a mandatory requirement for the L71 engine and ALL TI cars came with the 61 amp alternator??
Ed
Old Oct 11, 2011 | 05:15 PM
Mike Ward's Avatar
Mike Ward
Ed
I think we're not the ones that are confused.
Old Oct 11, 2011 | 05:28 PM
Ironcross's Avatar
Ironcross
Ed
because the correct alternator was not a 61 amp for a 435/L-71 and thats how this discussion started....61 amp altrnators were for AC cars.......I suppose one could order both a TI and AC Vette as all the TI ignition was is merely a option the same as a radio or a L-71 or whatever...except in the 435/L-71 cars TI was standard
that clear it up.......
Old Oct 11, 2011 | 05:37 PM
Mike Ward's Avatar
Mike Ward
Umm no.
61 amp alternator p/n 1100825 came on any 69 Corvettes that had A/C or TI, other than base engine which used 1100884 or L88/L89 which used 1100882. All three are 61 amp.
1100696 42 amp was used in '68 if K66 TI was specified.
To alternator
Old Oct 11, 2011 | 05:45 PM
restoman1's Avatar
restoman1
EDIT: Mike beat me to it, but here's my reply anyway...
RPO K66 required 6.25 amps to operate, compared to the standard points ignition which only required 2 amps. The higher amperage requirements necessitated a higher alternator output and the 61 amp alternator was used. I've attached a copy of the 69 AIM showing the 1100825 "generator assembly" (#2) that came with K66. The 1100825 alternator is rated at 61 amps.
And by the way, the "standard" alternator for the 1969 Corvette was rated at 42 amps. 37 amps alternators weren't used.
But I think Mike hit it on the head and you might be thinking 1968 (37 amp alternator standard, 42 amp with K66 and 61 amp with C60).
Ed
Old Oct 11, 2011 | 06:43 PM
Ironcross's Avatar
Ironcross
OK gentlemen, I guess you got me....and apoligize for my incorrect statements.......but I have a 1968 and my OE alternator was on the parts counter and one day it got leggs.....and no way could I look at its amps...I thought it was a 37 A or 42 A ..... and I see the poster did refer his as a 1969....and thus makes a question as to what was on a 68?.....I dont think it was a 61 A.......but am I wrong again......
If I would have went and read the above posts completely I would have the answer
I quit, ...put a zipper on my mouth.....
Old Oct 11, 2011 | 07:18 PM
restoman1's Avatar
restoman1
Don't sweat it. Chevrolet has never been known for the simplistic approach, and things can be VERY confusing at times!
I had a professor in college that had a saying, and it fits me perfectly...
"I am never wrong. Once I thought I was but I was mistaken!"
Ed
